Tarkin
Revision as of 19:36, 30 May 2024 by Bwatt (talk | contribs) (Undo revision 2902 by Bwatt (talk))
Tarkin is the new large-format laser cutter in the space, currently the most capable of our lasers for 2-d operations. It's a hot-rod custom-built laser cutter based on an RF CO2 10.6um laser and the latest in C-rail linear rails and a closed-loop servo-stepper motion system with a Ruida RDC6445G controller running Lightburn software. It features 225W of power on a 1.6M x 1.0 M (63"x39") cutting bed, powered Z, 16MP alignment camera, and air assist.
Setup
1. Locate Fire Extinguisher
2. Main Power Switch
Tarkin's chiller switch
3. Chiller switch
4. Locate E-STOP button
Important Terms
Machine bed
Material
Lightburn
Workspace
Lightburn's work area on the PC. This is the same as the machine bed only if you make the workspace size the same as machine bed size and operate in absolute coordinates. Otherwise, where your job is placed on the workspace is not necessarily where the job will be when you go to the machine bed, and your workspace can be declared in a different size than the machine bed. Note that in either case, your job (the actual content) will probably be smaller than the whole declared workspace, and cannot be located outside the workspace when you actually want to send it to the laser. Raster content cannot use the entire width of the workspace as it requires enough extend space on either side to decelerate and accelerate back. You will not know if it has enough extend space until trying to run the job at the machine.
Job
User origin
Vector Cutting
Vector Engraving
Rastering
Fill
Focusing
Focus tool
Origins
Absolute coords
User origin
Camera-placed absolute coords
These all produce similar burns, but the top and bottom settings attempts waste runtime
Rastering
MAX RASTER
Types of Rastering:
FILL
GRAYSCALE 2D
Depth Map
DITHER/HALFTONING 2D
Rastering with Focus+
Overburn apparent on cleaning
0.1mm, too close
Shutdown
Turn off main power
Turn off chiller
Order is NOT important
Usable
Plywood quality and "Patches"
Prohibited
NO PVC
NO PTFE (Teflon)
Produces toxic and corrosive gases
NO Polycarbonate
NO METAL
NO FOOD
Copper Wire Flame Test
When in doubt, there is a copper wire "flame test" specifically for the presence of toxic/corrosive chlorine as found in PVC:
Machine Errors
Causes:
WATER PROT
SYS ALARM, MACHINE PROTECTED
Likely causes:
FRAME SLOP
A Lightburn Material Database for Tarkin's material settings ready to install on your machine is located here [TBD: add '$wgFileExtensions = array( "clb", lbset" );' to LocalSettings.php]
Current Quirks
Table shifting when moving Z
Fixed air assist
Expected resolution
Drive Faulting
Cone clipping
