Elegoo Mars 2 Pro
Asmbly owns the ELEGOO Mars 2P SLA printer.
| Manufacturer | Elegoo |
| Model | Elegoo Mars 2 Pro |
| Technology | UV Photocuring |
| Printing Speed | 30 - 50mm/h |
| Z Axis Accuracy | 0.00125mm |
| XY Resolution | 0.05mm (1620 * 2560) |
| Build Volume | 129mm(L) * 80mm(W) * 160mm(H) |
| Light Source | UV Integrated Light (Wavelength 405 nm) |
| Weight | 6.2kg |
| Operation | 3.5-inch Capacitive Touch Screen |
| Power Requirements | 100-240V 50/60Hz |
| Printer Dimensions | 20cm(L) * 20cm(W) * 41cm(H) |
- Keep the Mars 2 Pro 3D Printer and its accessories out of the reach of children.
Resin Safety
- Avoid breathing vapors.
You may purchase resin here.
Available Resin Materials
Leveling the Bed
Tool Use
- What to clean
- How to clean
- Where to dispose of waste
Example for Miter Saw:
- Brush off top surface
- Brush around machine
- Sweep floor
- Wall vacuum hose works well
SIG Information (if relevant)
