PolyPrinter 229 Overhaul
| Status | Active |
| Video Feed | Unknown |
| Manufacturer | Polyprinter |
| Model | 229 |
| Nozzle Size | 0.4mm |
| Nozzle Type | Brass(?) |
| Nozzle Count | 1 |
| Filament Size | 1.75mm |
| Print Volume | 229 x 229 x 229mm |
| Max Bed Temperature | 125(?)C |
| Max Nozzle Temperature | 300(?)C |
| Max Print Speed | 250(?)mm/s |
| Extruder Type | Direct |
| Manual | Unknown |
| Network Address | Unknown |
Etiquette (if relevant)
Example:
Tool Use
- What to clean
- How to clean
- Where to dispose of waste
Example for Miter Saw:
- Brush off top surface
- Brush around machine
- Sweep floor
- Wall vacuum hose works well
SIG Information (if relevant)
Common Projects
Critical Info!
- Requires use of KISSlicer
