PolyPrinter 229 Overhaul
Status | Active |
Video Feed | Unknown |
Manufacturer | Polyprinter |
Model | 229 |
Nozzle Size | 0.4mm |
Nozzle Type | Brass(?) |
Nozzle Count | 1 |
Filament Size | 1.75mm |
Print Volume | 229 x 229 x 229mm |
Max Bed Temperature | 125(?)C |
Max Nozzle Temperature | 300(?)C |
Max Print Speed | 250(?)mm/s |
Extruder Type | Direct |
Manual | Unknown |
Control Interface | Unknown |
Network Address | Unknown |
- Ensure that the printer is used in a well-ventilated area.
- Keep the side doors and the hood closed while extruding or printing, and for a few minutes after printing.
- Do not touch the bed surface while it's hot.
- Observe the bed temperature and wait for it to drop below 45°C before removing the part from the printer.
- Do not touch the extruder head block or nozzle while it's hot.
- Never use metal tools on the bed.
Members are encouraged to bring their own filament for 3D printing projects. However, for your convenience, a limited supply of free filament is available for use with the Makerspace 3D printers. This filament can be found on the table next to the printers, as well as in the storage area beneath them. Please note that the free filament is intended for community use, so availability may vary.
The PolyPrinter is typically set to print with ABS.
Slicing and Printing
KISSlicer is the slicing app used to create the Gcode for the PolyPronter, the software that controls the PolyPrinter. To begin a print, follow these steps.
- Open an .stl file in KISSlicer.
- Adjust the parameters for your Gcode. Ensure that the Printer Tab is selected to PolyPrinter
- Slice the file and save it as a Gcode.
- In PolyPronter, connect PolyPronter to the PolyPrinter by clicking the "Connect" button.
- Click "Load File" and import your Gcode into PolyPronter.
- Preheat the extruder and bed by selecting "Set on the correct temperature for the extruder and bed. Be sure to preheat both the extruder and bed before starting a print.
- When the part is read, select "Print" to begin printing.
Feeding Filament
Always trim the end of a filament before feeding it into the extruder. Follow these steps to feed the filament:
- Preheat the extruder.
- Press down on the yellow lever above the extruder.
- While holding the lever down, push the filament into the extrusion hole.
- Once the melted filament begins to ooze out of the nozzle, release the lever.
- After feeding the filament, press the "Extrude" button to ensure the filament is properly prepared.
Removing Filament
Follow these steps to remove the filament:
- Heat the extruder to at least 230°C.
- Press down on the yellow lever to release the pressure on the filament.
- Pull the filament up carefully, avoiding contact with the hot tip to prevent burns.
Cleaning a Printed Part
- A pair of small needle-nose pliers can be used to tear away support.
- When using a knife, always cut away from your body to avoid injury.
- Cleaning a part should be done on a solid work surface. Applying downward pressure ensures that the surface absorbs the force, preventing slips.
- Finger guards or leather gloves are recommended to help avoid minor cuts.
- Use a tool that is sharp enough to cut cleanly but not so sharp that it digs too deeply into the plastic.
Re-taping the Bed
The bed should always remain taped for optimal printing performance. Over time, the tape can become worn due to oils and scratches, making it necessary to re-tape the bed. PET tape, which is used for this purpose, can be found beneath the printer. Follow these steps to properly re-tape the bed:
- Raise the extruder by at least 100 mm using PolyPronter.
- Ensure that both the extruder and the bed are cool.
- Remove the old tape.
- Apply the new tape starting at the front edge of the bed, pressing down from one side to the other with a slim tool. Ensure the tape is aligned properly and now wrinkles or bubbles are present.
- Repeat with the next strip of tape, ensuring the edges barely touch but do not overlap the previous strip.
- Leave extra tape hanging from each side for potential adjustment if needed.
SIG Information (if relevant)
Common Projects
Critical Info!
- Requires use of KISSlicer
