Tormach PCNC 1100
Revision as of 18:05, 15 September 2024 by Aneel (talk | contribs) (→‎Work Holding: Added warning about travel being smaller than the fixture plate)
Tormach PCNC 1100 Series 3
  • 1.5hp R8 Spindle
  • Table Size: 34" x 9.5"
  • Table Slots: 3 Slots 5/8"
This machine rotates the spindle very rapidly. Don't wear loose clothing when operating this machine. It may be hard to see exactly where rapidly spinning tools are, particularly fly cutters.
Do not reach into the enclosure while the machine is moving. The space bar triggers FEEDHOLD, which stops feeding, but does not stop the spindle. Stop the spindle as well as stopping feeding (bed movement) by sliding the RPM slider to 0% on the console. The STOP button will reset your program to the beginning.
Keep the enclosure doors closed as much as possible. Objects may be sent flying in any direction, including detached pieces, or the entire part being machined if work holding fails.
Maximum Sizes and Weights
  • Weight: 500 lbs
Feeds and Speeds
Setup
Basic Operation
Turning on the Machine
  • Check the oiler, which is on the lower left side of the machine. Contact a steward if the oil level is low
  • Oil reservoir level
  • Check the coolant pressure. Open the valve fully and click the COOLANT button on the console. The stream should have enough pressure to remain straight over several inches. If you need to add coolant, mix 5-10% concentrate and the rest distilled water. The concentrate is a brown liquid that should be in the tall cabinet in the machining area. Give it a good shake to mix it before adding it to the reservoir. You can pour the coolant into the drain in the enclosure. Pay attention to the coolant pressure as you operate the tool. If it gets low, pause your job and add more coolant.
  • Good coolant flow
  • Insufficient flow
  • Coolant concentrate
  • Mixing the coolant
Transferring Files
Preparing Tools
    • There is a tool tightening fixture mounted on the cabinet top. To tighten, insert the collet in the left side of the bushing and tighten with the wrench. To loosen, insert the collet in the right side of the bushing and loosen with the wrench
  • A tool in an ER20 collet on the left side of the fixture with a wrench
Inserting & Removing Tools
  • To insert:
    • Open the spindle cover door
  • To remove:
Work Holding
    • The fixture plate is 34" x 12". The Tormach travel is only 18" x 9.5". This means that much of the fixture plate can't be reached by the spindle, so before fixturing a part to the table, make sure it will be accessible.
    • The holes are spaced 1.25" on-center
    • Diagram with dimensions
Referencing
  • Click Ref X and Ref Y
Probing
Software
Tooling
Machining Shop Space Team
SIG Information
Common Projects
