Ceramics Policy
Revision as of 19:58, 1 May 2025 by Laurel (talk | contribs)
Introduction
Ceramics Safety & Information (CSI) is the required free class you must take before access to the studio with membership is granted.  We are all caretakers of the shared space, so the cleanliness and maintenance is up to you!
Usage Areas
Tools
  • Pottery Wheels: 5 machines available: Max booking is 5 hours of time
  • Extruder:  1 tool available: Comes with the extruder table next to it, max booking is 3 hours of time
    • If it is not booked you can rebook the Extruder in Skedda up to 3 more hours
  • Slab Roller: 1 tool available: Max booking is 3 hours of time
    • If it is not booked you can rebook the Slab Roller in Skedda up to 3 more hours
    • NOTE: If you are making a lot of slabs, it is recommended you Book a Table with the note, “Using Slab Roller” as a User in the studio to give you somewhere besides your shelf  to put the slabs.
Studio User
You must book yourself as a User if you plan on sitting at a Handbuilding Table, regardless of tool booking. You must also reserve time for each tool you plan to use on Skedda (see above). It is your responsibility to CHECK SKEDDA to make sure the tool is not booked. Allow for clean up time within your booked time, NOT after. Members booked in Ceramics at the same time should work together to clean and coordinate space use.
  • Handbuilding Tables: 8 Users can Book up to 5 hours of time between 2 tables (4 Users/table)
  • Glaze Area: 2 Users can Book up to 5 hours at a time in the Glaze area
    • NOTE: If you are glazing a large amount of items, please book a User table space in addition to the glaze area and put a note on the Table booking you will be, “Using Table for Glazing”, and on the Glaze booking that you will be, “Using a table”
    • If it is not booked you can rebook the Table  in Skedda up to 5 more hours
Community Tools/Areas
  • We have a Blue Ox Air filtration system to be installed soon to help cut back on particulates in the air
Studio Shelves
Kilns/Kiln Room
Kiln Shelves
Members are responsible for moving their OWN pieces to the Greenware and Glaze Shelves when ready.
    • STUDENTS: we have Open hours with a Steward on Duty they can come by to retrieve their piece
      • Mondays: 4-8
      • Wednesdays: 4-8
      • Saturdays: 12-4
      • Mondays: 4-8
      • Wednesdays: 4-8
      • Saturdays: 12-4
Clay & Glazes
Clays Provided in Studio
  1. Cinco Blanco
  2. Buffalo Wallow
Glazes Provided in Studio
All glazes provided are lead free and Food Safe.
Lay down brown paper provided to avoid getting glaze on the clay tables or drying boards.
Clean up glaze brushes and bowls provide for community use when finished.
These Mid-fire Glazes are currently available in studio for Members & Classes to use:
Amaco Celadon Line
  1. Snapdragon
  2. Tangelo
  3. Marigold
  4. Succulent
  5. Pear
  6. Sky
  7. Cobalt
  8. Mulberry
  9. Snow
  10. Obsidian
  11. Mixing Clear
Amaco Satin Matte
Satin Mattes break slightly over edges and texture and boast a soft satin feel. These glazes are formulated to be 100% mixable. Use Clear Satin to lighten color tones, Satin Black to create shades, and Satin White to create tints.
  1. Red
  2. Orange
  3. Goldenrod
  4. Moss
  5. Dark Blue
  6. Marble
  7. Black
  8. Satin Clear
Mayco Fundamentals Underglaze
  1. Fire Engine Red
  2. Orange
  3. Bright Yellow
  4. Forest Green
  5. Bright Blue
  6. Wild Violet
  7. Chocolate
  8. China White
  9. Jet Black
Dip Glazes
Mayco Jungle Gems
  1. Sassy Orange
  2. Cherry Limeade
  3. Blue Guppy
  1. Amaco Celadons, $21.00
  2. Amaco Satin Matte, $21.00
  3. Mayco Fundamentals Underglaze, $19.95
  4. Potter’s Choice, $22-$37
  5. Jungle Gems, $22.15
Kiln Check-In Procedures
Firing Sign In Process
Firing System
Usage Violations
    • Kiln damage
Clay Body
  1. Bisque Fire:
Glaze
  1. Glaze Fire:
Discipline/Violations Policy
