Ceramics Policy
Introduction
Asmbly Policies outlined in the Member Handbook, HERE apply to ALL shop areas including Ceramics. However Ceramics has some additional policies specific to the studio that are outlined below.
Ceramics Safety & Information (CSI) is the required free class you must take before access to the studio with membership is granted. We are all caretakers of the shared space, so the cleanliness and maintenance is up to you!
Usage Areas
Tools
You must reserve time for each tool you plan to use in Skedda. It is your responsibility to CHECK SKEDDA to make sure the tool is not booked. Allow for clean up time within your booked time, NOT after. Members booked in Ceramics at the same time should work together to clean and coordinate space use.
- Pottery Wheels: 5 machines available: Max booking is 5 hours of time
- When your time ends, check Skedda.
- If it is not booked you can rebook the Wheel in Skedda up to 5 more hours
- Extruder: 1 tool available: Comes with the extruder table next to it, max booking is 3 hours of time
- If it is not booked you can rebook the Extruder in Skedda up to 3 more hours
- Slab Roller: 1 tool available: Max booking is 3 hours of time
- If it is not booked you can rebook the Slab Roller in Skedda up to 3 more hours
- NOTE: If you are making a lot of slabs, it is recommended you Book a Table with the note, “Using Slab Roller” as a User in the studio to give you somewhere besides your shelf to put the slabs.
Studio User
You must book yourself as a User if you plan on sitting at a Handbuilding Table, regardless of tool booking. You must also reserve time for each tool you plan to use on Skedda (see above). It is your responsibility to CHECK SKEDDA to make sure the tool is not booked. Allow for clean up time within your booked time, NOT after. Members booked in Ceramics at the same time should work together to clean and coordinate space use.
- Handbuilding Tables: 8 Users can Book up to 5 hours of time between 2 tables (4 Users/table)
- It is not a specific table spot, just that you plan on using some table space
- If it is not booked you can rebook yourself as a User in Skedda up to 5 more hours
- Glaze Area: 2 Users can Book up to 5 hours at a time in the Glaze area
- NOTE: If you are glazing a large amount of items, please book a User table space in addition to the glaze area and put a note on the Table booking you will be, “Using Table for Glazing”, and on the Glaze booking that you will be, “Using a table”
- If it is not booked you can rebook the Table in Skedda up to 5 more hours
Community Tools/Areas
- Please clean all tools you use from the communal tools and return to their storage location.
- Place brown paper on handbuilding tables if applying glaze
- Glaze should be kept from contaminating the canvas table surfaces
- Ceramic Dust: Silica dust is going to be present in the studio
- It is highly recommended you wear a mask while in the studio for prolonged and repetitive periods; especially while cleaning up!
- Use your own personal discretion
- NEVER make another person feel bad for wearing a mask.
- NEVER use a broom, WATER is the best way to safely clean up clay.
- If there is dry clay on the canvas topped tables, wet it with water to remove
- Do NOT scrape dry clay, it will kick up unnecessary dust
- NO FOOD in the Studio, you risk eating glaze accidentally (Closed beverage containers OK)
- We have a Blue Ox Air filtration system to be installed soon to help cut back on particulates in the air
Studio Shelves
- Do NOT touch anything on any member’s shelf that is not yours
- Look with your eyes, not your hands
- Do not be the one who breaks a member’s piece accidentally
- Do NOT touch anything on the Steward Shelves
- Do not be the one who breaks a Steward’s piece accidentally
- Do NOT touch anything on any class shelf that is not yours
- Kiln Operators will be responsible for moving Class pieces to the Greenware shelf
- They will monitor moisture levels to ensure kiln safety
- They will notify they students of the status of their pieces and pick up time limits
Kilns/Kiln Room
- If you see anyone in the room that is not a Kiln Operator with a clear name tag stating such, it is a Policy violation
- Under NO circumstances are you allowed to touch, turn on/off, or move the kilns & kiln furniture
- NEVER touch the kilns if not authorized
- NEVER operate or change the setting of the Kiln Vents if not authorized
Kiln Shelves
Members are responsible for moving their OWN pieces to the Greenware and Glaze Shelves when ready.
- Greenware: BONE DRY pieces ready to be fired for the 1st time
- Pieces may sit here a bit depending on the Kiln firing schedule or the Kiln Operator's discretion on moisture levels
- Bisque Fire: Pieces that have come out of their first firing and are in the Bisque state
- Pieces will sit on the Bisque Shelf for 2 weeks total
- After the two weeks the piece will be removed and disposed of
- MEMBERS: you have 21 hours/day to move your piece to your shelf or to take home, so get it moved!
- STUDENTS: we have Open hours with a Steward on Duty they can come by to retrieve their piece
- Mondays: 4-8
- Wednesdays: 4-8
- Saturdays: 12-4
- Glaze Fire: Bisque fired, Glazed pieces ready to be fired for the final time
- Pieces may sit here a bit depending on the Kiln firing schedule, and the Kiln Operator's discretion on glaze moisture levels/application/adherence
- Ready to Pick Up(Pick Up Shelf): Pieces that have come out of final firing and are Glazed and ready
- Pieces will sit on the Pick Up for 2 weeks total
- Mondays: 4-8
- Wednesdays: 4-8
- Saturdays: 12-4
- ALL pieces not picked up in their allotted time WILL be disposed of!!!
Clay & Glazes
Clays Provided in Studio
- Purchase Clay at the Square Reader
- Place use provided Sharpie to write your name on your bags, or box, of clay
- This is visual proof of your purchase so there is no confusion once the clay is on your shelf.
- Buffalo Wallow w/ Grog, $21.00/25lb bag
- Cinco Rojo, $20.00/25lb bag
- Cinco Rojo w/ Grog, $21.00/25lb bag
- Cone 5 Porcelain, $24/25lb bag
- Laguna Speckled Buff, $28.50/25lb bag
- Laguna B Mix, $30.50/25lb bag
- Dark Chocolate No. 32, $12.50/5lb bag
Glazes Provided in Studio
All glazes provided are lead free and Food Safe.
Lay down brown paper provided to avoid getting glaze on the clay tables or drying boards.
Clean up glaze brushes and bowls provide for community use when finished.
Amaco Celadon Line
Amaco Satin Matte
Satin Mattes break slightly over edges and texture and boast a soft satin feel. These glazes are formulated to be 100% mixable. Use Clear Satin to lighten color tones, Satin Black to create shades, and Satin White to create tints.
Mayco Fundamentals Underglaze
- Fire Engine Red
- Orange
- Bright Yellow
- Forest Green
- Bright Blue
- Wild Violet
- Chocolate
- China White
- Jet Black
Dip Glazes
Mayco Jungle Gems
- Amaco Celadons, $21.00
- Amaco Satin Matte, $21.00
- Mayco Fundamentals Underglaze, $19.95
- Potter’s Choice, $22-$37
- Jungle Gems, $22.15
Kiln Check-In Procedures
Firing Sign In Process
- Follow the QR Code to a Google Form for each type of firing
- Check in ALL your pieces with just one Google Form.
- Fill out ONE form for Bisque, and a NEW form for Glaze
2. Fill out one WHITE paper slip for EACH of your pieces
- This will serve as a physical record the Kiln Operators can track as things come in and out of the Kilns.
Firing System
- Bisque Fired at Cone 04 (~1900-1940℉)
- Low-fire Glaze at Cone 04 (~1940℉)
- Mid-fire Glaze at Cone 6 (~2200℉).
- If you want to put glaze all over and risk it getting stuck to the support, you must discuss this with the Lead Kiln Operators and be aware it may cause damage to your piece
- This is not required at this time, just strongly advised
- If serious issues arise it may be made an official policy
- The Kiln Operators reserve the right to ask you to make any corrections to your
Usage Violations
- Usage of unapproved clay & glazes will be recorded and not allowed
- It may result in damage to your or other’s pieces
- Kiln damage
- Repeated reported violations will result in not being allowed to put pieces in the kiln firings AND/OR prohibition from the studio
- As of 4/22/2025 the Kilns will be fired to:
- Clay or glazes that need a cooler or hotter maturation temperature will currently not be accepted.
- This could change in the future at the discretion of Asmbly
- Special projects may be considered
- Clay and glaze test pieces will be checked in the same way as other pieces, with the “Kiln Check In Form”, but will be placed on the Test Shelves
- We will not accept Glazes with Lead in any form in the studio
- The Skutt Kiln (Helios) is the test kiln
- Your piece may wait for some time, until we have a full load, and is fully dry before being fired
- This is up to the discretion of the Kiln Operators
Clay Body
- Bisque Fire:
- Please make a small piece out of your clay body, such as a small mug, bowl, sculpture, etc.
- The piece should be no more than 6” x 6” x 6”
- Please be prepared to possibly lose this piece as it could crack or break in the test
- Please allow it to dry, and then dry some more, before placing on the Greenware Test Shelf
- The longer you let it dry, the less time it will spend waiting to go in to the kiln
- We will not accept pieces that are still wet
- If it does not melt, crack excessively or otherwise seem dangerous it will be approved to be used along with our other approved clay bodies.
Glaze
- Glaze Fire:
- Please make a small piece, such as a small mug, bowl, sculpture, etc.
- If you do not have a piece to test your glaze on, a vertical test tile will be provided to you by Asmbly made of Cinco Blanco
- Glaze your piece with the glaze you are testing.
- Leave 1” of unglazed ceramic at the bottom to test if it runs or drips excessively
- Leave ¼” - ½” unglazed if using a provided vertical test tile
- Please apply the same glaze technique on the test piece you plan to apply on the actual piece, in order to get an accurate test.
- Same number of layers, colors, overlaps of glazes, etc.
- If it does not melt, crack excessively, craze past your liking, or otherwise seem dangerous it will be approved to be allowed in with the other glazes
Discipline/Violations Policy
