How to Glaze
Revision as of 00:17, 16 June 2025 by Nona (talk | contribs)
What Is Allowed
What Is Not Allowed
Mixing Policy
Glaze Testing
Approval & Communication
For approvals, contact:
How to Test a Glaze
Please Note:
  • You may lose the test piece
Summary
  • Only studio-approved commercial glazes are permitted — no exceptions.
  • Dry commercial glazes may only be mixed under supervision — members cannot mix on their own or off-site.
  • No homemade recipes, experimental blends, or member-sourced raw materials are allowed.
  • All glaze testing is separate from regular firings and must be placed on designated shelves.
  • Email Seth or Perla for all material approval and testing coordination.
