How to Glaze
Revision as of 00:39, 16 June 2025 by Nona (talk | contribs) (Summary)
Before You Begin:
  • Book the Glaze Area on Skedda before using. Max 5 hours per session. All tool use counts toward your weekly 25-hour limit.
Glazing: Step-by-Step
  1. Ensure your piece is bisque fired and free from dust (wipe gently with a damp sponge)
  2. Apply wax resist to the bottom of your piece using the small designated wax brushes provided
    • Clean wax brushes: Pick wax off into trash, then rinse in HOT water
  4. Pour glaze into a small bowl before brushing. Do not dip brushes directly into the main glaze jars
  5. Apply glaze evenly
    • Avoid over-applying to prevent drips and runs
  6. Leave the bottom of the piece unglazed
  7. Clean glaze brushes: Rinse in the sink; use hand soap if needed — black glaze may require extra scrubbing
  8. Label your piece clearly if it's part of glaze testing
  9. Place on the Glaze Fire shelf for kiln loading
Please Note:
  • Improper glazing or unlabeled pieces may be held back from firing
What Is Allowed
Please Note:
What Is Not Allowed
Mixing Policy
Glaze Testing
Approval & Communication
For approvals, contact:
How to Test a Glaze
Please Note:
  • You may lose the test piece
Summary
  • Email Seth White (seth.white@asmbly.org) or Perla Darnell (perla.darnell@asmbly.org) for all material approval and testing coordination
