How to Glaze
Revision as of 15:03, 10 July 2025 by Nona (talk | contribs)
Before You Begin:
  • Book the Glaze Area on Skedda before using. Max 5 hours per session. All tool use counts toward your weekly 25-hour limit.
Glazing: Step-by-Step
  1. Ensure your piece is bisque fired and free from dust (wipe gently with a damp sponge)
  2. Apply wax resist to the bottom of your piece using the small designated wax brushes provided
    • Clean wax brushes: Pick wax off into trash, then rinse in HOT water
  4. Pour glaze into a small bowl before brushing. Do not dip brushes directly into the main glaze jars
  5. Apply glaze evenly
    • Avoid over-applying to prevent drips and runs
  6. Leave the bottom of the piece unglazed
  7. Clean glaze brushes: Rinse in the sink; use hand soap if needed — black glaze may require extra scrubbing
  8. Label your piece clearly if it's part of glaze testing
  9. Place on the Glaze Fire shelf for kiln loading
Please Note:
  • Improper glazing or unlabeled pieces may be held back from firing
What Is Allowed
Please Note:
What Is Not Allowed
Mixing Policy
Glaze Testing
Approval & Communication
For approvals, contact:
How to Test a Glaze
Please Note:
  • You may lose the test piece
Approved Glazes at Asmbly
Asmbly is a community of makers, so we encourage exploration and creativity. Below are some of the glazes approved for use in our studio:
Underglazes (Mayco Brand)
  • Versatile & Food Safe: Use for full coverage or in designs on clay, greenware, or bisque. Food safe when covered with a clear glaze.
  • Firing Range: Cone 6 - Cone 10 (We fire to cone 6).
  • Application: Shake well, apply 2-3 coats to wet clay or bisque, avoiding glaze pooling in textured areas.
  • Firing: Fire to cone 04, then apply clear glaze and fire to cone 06/05 for earthenware or cone 5-10 for stoneware.
Celadon Glazes (Amaco Brand)
  • Translucent & Glossy Finish: Ideal for highlighting texture on your pieces.
  • Firing Range: Cone 5 - Cone 6 (Food safe).
  • Available at Asmbly: Some colors available for members to use at no extra cost. Other colors can be brought in without testing.
  • Application: Follow the manufacturer’s instructions for number of coats. No need to mix with other glazes.
  • Fluid Colors & Effects: Great for smooth or textured pieces. Not food safe.
  • Firing Range: Cone 5 - Cone 6.
  • Available at Asmbly: Some samples available, but members must purchase other colors.
  • Application: Test glazes first on a vertical test tile. If combining glazes, test on a tile before applying to pieces.
  • Note: Results can vary due to glaze interaction, especially when layering.
  • Soft Satin Feel: Semi-opaque glazes that break over texture and edges.
  • Available at Asmbly: Some colors in-house for free. Members can bring in other colors without testing.
  • Application: Follow the manufacturer’s instructions. No need to mix with other glazes.
  • Colorful & Textured: Glass frit bursts create intricate patterns.
  • Food Safety: Not 100% food safe due to potential crazing.
  • Available at Asmbly: Some colors available for members to use, but members must purchase others.
  • Application: Shake well and apply 2-3 coats to bisque. Stir frequently, as crystals can settle. Avoid heavy application at the bottom of pieces to prevent glaze melting onto kiln shelves.
  • Note: The glass crystals bloom during firing, creating unique results each time.
Summary
  • Email Seth White (seth.white@asmbly.org) or Perla Darnell (perla.darnell@asmbly.org) for all material approval and testing coordination
