Jet 12 21 Lathes
Revision as of 23:13, 8 September 2025 by Rolo (talk | contribs) (Created page with "The Central Texas Woodturners Association (CTWA) is hosting six Jet midi lathes for use. The first number in the name represents the "swing" or largest diameter your workpiec...")
The first number in the name represents the "swing" or largest diameter your workpiece can be, while the second number represents the distance between centers or maximum length your workpiece can be. In other words, the Jet lathes can accommodate material 12" wide by 21" long.
How to Book: These are currently NOT bookable on Skedda and are only available for Asmbly classes or CTWA classes.
Members must complete the Intro to the Wood Lathe Class before using this tool
This tool is owned by Central Texas Woodturners Association https://ctwa.org/ and hosted at Asmbly for members to use. Please submit a problem report if maintenance is required.
