Supermax 25-50 Drum Sander
Revision as of 15:09, 1 December 2021 by Admin (talk | contribs) (Created page with "The SuperMax 25-50 is the largest open-ended drum sander on the market, sanding up to 25" wide in a single pass and 50" in two passes. Maximum material thickness is 2-1/4"; m...")
The SuperMax 25-50 is the largest open-ended drum sander on the market, sanding up to 25" wide in a single pass and 50" in two passes. Maximum material thickness is 2-1/4"; minimum is 1/32"
