How to Glaze
Before You Begin: Our glazing and cleaning procedures MUST be followed if you intend to use our communal products, glazing spaces, and kiln firing.
  • DO NOT dip brushes directly into glaze jars. Pour out glaze into provided bowls or cups
    • Keep 2 oz plastic cups of glaze labelled and on personal shelves
  • DO NOT return poured out glaze to glaze jars--these must remain uncontaminated
  • DO NOT overglaze your piece--it will be rejected. 2-3 coats is all that is necessary.
  • DO NOT use unapproved glazes (process listed below for approval of glazes)
  • You must WAIT for each layer to fully dry before added another glaze layer
  • DO use wax resist on the bottom of your piece, 1/4" if using one glaze, 1/2" if using multiple glazes. Wipe off any glaze that dripped onto this area before loading it onto the kiln shelves
Glazing: Step-by-Step
In-House Dip Glazes:
  • Ensure your piece is bisque fired and free from dust BEFORE glazing (wipe gently with a damp sponge)
  • Apply wax resist to the bottom and 1/2" space up sides of your piece using the small, blue designated-wax brushes provided at the glazing station
    • Clean wax brushes: Pick wax off into trash, then rinse in HOT water or use provided alcohol
  • Stir glaze in bucket vigorously with the brush
    • scrub dense build up on the edges into the mix until you have an even consistency
  • Dip for 1-2 seconds
  • Rest piece on top of a glazing table or paper-covered handbuilding table as the glaze layer dries
  • WAIT until the glaze is evenly dried before dipping again
    • Look for an even color, discoloration means that the glaze is not dry.
  • Stir glaze AGAIN scrubbing dense build up on the edges into the mix until you have an even consistency
  • Dip AGAIN if coverage is not complete (1-2 seconds)
  • Wipe off excess glaze from wax-resisted areas
  • Place piece on HOUSE DIP GLAZE SHELF
  • Prepare yourself for the wondrous mystery of glaze
Amaco Celadon Glazes on Table in Pints:
  1. Ensure your piece is bisque fired and free from dust BEFORE glazing (wipe gently with a damp sponge)
  2. Apply wax resist to the bottom and 1/4" space up sides of your piece using the small designated wax brushes provided
  4. Pour glaze into a small bowl before brushing. DO NOT DIP brushes directly into the main glaze jars
  5. Apply glaze evenly
    • Avoid over-applying to prevent drips and runs
    • Reserve 1/2" of unglazed area at the bottom of your piece if:
      • thickly applied;
      • if it is a fast running type of glaze (fluxes, rutiles, are examples of fast running glazes. Read the manufacturers labels and they will let you know)
      • or if you are layering more than one type of glaze
  6. WAIT for each glaze layer to dry before applying again.
  7. Leave the bottom of the piece unglazed
  8. Clean glaze brushes: Rinse in the sink; use hand soap if needed — black glaze may require extra scrubbing
  9. Dry and return brushes to their designated containers
  10. Label your piece clearly if it's part of glaze testing
  11. Place on the Glaze Fire shelf and use check in form for kiln shelves
Please Note:
  • Improper glazing or unlabeled pieces will be held back from firing and will be placed in the "rejected" shelf
What Is Allowed
Please Note:
What Is Not Allowed
Mixing Policy
    • Under the supervision of the kiln operators, ceramics space lead, or other approved persons
Glaze Testing
Approval & Communication
For approvals, contact kilnops@asmbly.org
How to Test a Glaze
Please Note:
  • You may lose the test piece
Approved Glazes at Asmbly
Underglazes (Mayco Brand)
  • Versatile & Food Safe: Use for full coverage or in designs on clay, greenware, or bisque. Food safe when covered with a clear glaze.
  • Firing Range: Cone 6 - Cone 10 (We fire to cone 5).
  • Application: Shake well, apply 2-3 coats to wet clay or bisque, avoiding glaze pooling in textured areas.
  • Firing: Fire to cone 04, then apply clear glaze and fire to cone 06/05 for earthenware or cone 5-10 for stoneware.
Celadon Glazes (Amaco Brand)
  • Translucent & Glossy Finish: Ideal for highlighting texture on your pieces.
  • Firing Range: Cone 5 - Cone 6 (Food safe).
  • Available at Asmbly: Some colors available for members to use at no extra cost. Other colors can be brought in without testing.
  • Application: Follow the manufacturer’s instructions for number of coats. No need to mix with other glazes.
  • Fluid Colors & Effects: Great for smooth or textured pieces. Not food safe.
  • Firing Range: Cone 5 - Cone 6.
  • Available at Asmbly: Some samples available, but members must purchase other colors.
  • Application: Test glazes first on a vertical test tile. If combining glazes, test on a tile before applying to pieces.
  • Note: Results can vary due to glaze interaction, especially when layering.
  • Soft Satin Feel: Semi-opaque glazes that break over texture and edges.
  • Available at Asmbly: Some colors in-house for free. Members can bring in other colors without testing.
  • Application: Follow the manufacturer’s instructions. No need to mix with other glazes.
  • Colorful & Textured: Glass frit bursts create intricate patterns.
  • Food Safety: Not 100% food safe due to potential crazing.
  • Available at Asmbly: Some colors available for members to use, but members must purchase others.
  • Application: Shake well and apply 2-3 coats to bisque. Stir frequently, as crystals can settle. Avoid heavy application at the bottom of pieces to prevent glaze melting onto kiln shelves.
  • Note: The glass crystals bloom during firing, creating unique results each time.
Summary
  • Email kilnops@asmbly.org for all material approval and testing coordination
