Tarkin
Setup
1. Locate Fire Extinguisher
2. Main Power Switch
Tarkin's chiller switch
3. Chiller switch
4. Locate E-STOP button
Important Terms
Machine bed
Material
Lightburn
Workspace
Job
User origin
Vector Cutting
Vector Engraving
Rastering
Focusing
Focus tool
Origins
Absolute coords
User origin
Camera-placed absolute coords
Rastering
MAX RASTER
Rastering limit is 1500mm/sec. In general, rastering at 1500mm/sec is a good choice. This requires approx 100mm of Extend Space on either side.
Types of Rastering:
FILL
GRAYSCALE 2D
Depth Map
DITHER/HALFTONING 2D
Proper Line Interval
Rastering with Focus+
Determining Best Raster Power
Most jobs cutting with the "Fill" seek depth, not color change. Such as carving out block lettering with depth for signs.
But the goal of most grayscale or dithering is to produce the desired color change- typically the deepest color change possible. Initially, color typically deepens with more power. However, after a certain point the material may instead become lighter or change color entirely, and it may not be clearly evident until the wood is being cleaned of debris. This can happen because wood may pass a point where it starts to disintegrate into char and instead is removed entirely. In plywood, this may even reverse the color deepening trend because a veneer or ply of one type of wood is penetrated, exposing a different layer.
Overburn apparent on cleaning
0.1mm, too close
Rather, let's look at the original bitmap image itself. Select the image, then Tools->Adjust Image. There are sliders, dithering methods, and live, zoom-able preview of the image. Any changes here are DYNAMIC- it keeps the original bitmap and a list of these adjustments, rather than overwriting the bitmap with the adjusted image and forgetting the settings that adjusted it. If you OK out of this window, the design workspace shows the adjusted image. If you later enlarge the image size in the workspace, the line interval won't widen with it, it will be re-rendered with more lines, not wider intervals. If you return to Adjust Image, the original is still there along with all the adjustment sliders and dithering where you last set them.
This allows you to see what sort of detail the rastering will be able to do. We should not change our line interval, that will NOT add detail, just create overlap that breaks dithering by collapsing the dynamic range. If the detail cannot render, and we are already using the best focus, the only choice is to increase the image size to see the detail. But we contrast, brightness, gamma, and radius enhancement will enhance greatly. There is no fixed formula for this, it works off the exposure settings of the original image along with looking for the the specific detail you want to make most prominent. Adjust Image settings apply only to the selected image, not necessarily the entire Image Layer which may have multiple images in it. and are NOT saved in the Materials Library entry. The Materials Library only stores the speed, %power, dithering type, and line interval. The Adjust Image settings used on each image will save in the project, however.
Shutdown
Turn off main power
Turn off chiller
Order is NOT important
Usable
Plywood quality and "Patches"
Prohibited
NO PVC
NO Polycarbonate
NO METAL
NO FOOD
Copper Wire Flame Test
Machine Errors
Causes:
The machine is currently running a job, in a pause or prior halt-for-error- anything that leaves the red light on. If so, press STOP button to cancel.
WATER PROT
SYS ALARM, MACHINE PROTECTED
Likely causes:
FRAME SLOP
Current Quirks
Table shifting when moving Z
Fixed air assist
Expected resolution
Limit on Y size
Drive Faulting
Cone clipping
