Tarkin
Setup
1. Locate Fire Extinguisher
2. Main Power Switch
3. Chiller switch
4. Locate E-STOP button
Important Terms
Machine bed
Material
Lightburn
Workspace
Job
User origin
Vector Cutting
Vector Engraving
Rastering
Focusing
Origins
Absolute coords
User origin
Camera-placed absolute coords
Changing line interval from 0.125mm to 0.05mm takes 3x longer, but gives the same look. The fine-line approach has no benefit.
So, 800mm/sec 0.125 line interval for smaller Fills (or grayscale), and adjust ONLY the power for your depth of burn. 1500 mm/sec for larger Fills. Adjusting for lower speeds or smaller line intervals will not produce any different look than you could get with the right power level, they just waste time.
Rastering
MAX RASTER
Types of Rastering:
FILL
GRAYSCALE 2D
DITHER/HALFTONING 2D
Rastering with Focus+
Shutdown
Turn off main power
Turn off chiller
Order is NOT important
Usable
Plywood quality and "Patches"
Prohibited
NO PVC
NO Polycarbonate
NO METAL
NO FOOD
Copper Wire Flame Test
Machine Errors
Causes:
The machine is currently running a job, in a pause or prior halt-for-error- anything that leaves the red light on. If so, press STOP button to cancel.
WATER PROT
SYS ALARM, MACHINE PROTECTED
Likely causes:
FRAME SLOP
Current Quirks
Table shifting when moving Z
Fixed air assist
Expected resolution
Limit on Y size
Drive Faulting
Cone clipping
