Jet 22-44 Plus Drum Sander
Revision as of 23:09, 12 October 2021 by Jon (talk | contribs) (Jon moved page Jet 22-44 Plus to Jet 22-44 Plus Drum Sander)
Grit Jet Part Number Buy Online
36 60-2036 Buy on Amazon
60 60-2060 Buy on Amazon
80 60-2080 Buy on Amazon
100 60-2100 Buy on Amazon
120 60-2120 Buy on Amazon
180 60-2180 Buy on Amazon
220 60-2220 Buy on Amazon
This tool is owned by Joe Ngo and hosted at Asmbly for members to use. Please submit a problem report if maintenance is required.
