Module:Excerpt/doc
< Module:Excerpt
Revision as of 16:32, 13 December 2020 by mw>Sophivorus
This is the documentation page for Module:Excerpt
Template:Shared Template Warning
Page Module:Message box/ombox.css has no content.
| This module depends on the following other modules: |
This module implements Template:Excerpt.
- See Template:Excerpt for documentation on the template parameters
- See Module:Excerpt/config for configuration of this module
- See c:Data:I18n/Module:Excerpt.tab for localizing this module
Usage
Basic usage is:
{{#invoke:Excerpt|main}}
To localize the parameters to other languages and/or set default values, use the following pattern:
| files = {{{archivos|1}}} <!-- "archivos" means "files" in Spanish; set 1 as the default value -->
| lists = {{{listas|}}} <!-- "listas" means "lists" in Spanish -->
| tables = {{{tablas|}}} <!-- "tablas" means "tables" in Spanish -->
| only = {{#switch:{{{solo|}}} <!-- "solo" means "only" in Spanish -->
| listas = lists <!-- Notice the translation comes first here -->
| tablas = tables
See es:Template:Extracto for an example of a full localization with default values and other possibilities.
