Module:High-use
Revision as of 21:11, 1 November 2021 by w>GKFX (Link to https://linkcount.toolforge.org/ which is more detailed and mobile-friendly)
Documentation for this module may be created at Module:High-use/doc
local p = {}
-- _fetch looks at the "demo" argument.
local _fetch = require('Module:Transclusion_count').fetch
function p.num(frame, count)
if count == nil then
if yesno(frame.args['fetch']) == false then
if (frame.args[1] or '') ~= '' then count = tonumber(frame.args[1]) end
else
count = _fetch(frame)
end
end
-- Build output string
local return_value = ""
if frame.args[1] == "risk" then
return_value = "a very large number of"
else
return_value = "many"
end
else
-- Use 2 significant figures for smaller numbers and 3 for larger ones
local sigfig = 2
if count >= 100000 then
sigfig = 3
end
-- Prepare to round to appropriate number of sigfigs
local f = math.floor(math.log10(count)) - sigfig + 1
-- Round and insert "approximately" or "+" when appropriate
if (frame.args[2] == "yes") or (mw.ustring.sub(frame.args[1],-1) == "+") then
-- Round down
return_value = string.format("%s+", mw.getContentLanguage():formatNum(math.floor( (count / 10^(f)) ) * (10^(f))) )
else
-- Round to nearest
return_value = string.format("approximately %s", mw.getContentLanguage():formatNum(math.floor( (count / 10^(f)) + 0.5) * (10^(f))) )
end
-- Insert percentage of pages if that is likely to be >= 1% and when |no-percent= not set to yes
if count and count > 250000 and not yesno (frame:getParent().args['no-percent']) then
local percent = math.floor( ( (count/frame:callParserFunction('NUMBEROFPAGES', 'R') ) * 100) + 0.5)
if percent >= 1 then
return_value = string.format("%s pages, or roughly %s%% of all", return_value, percent)
end
end
end
return return_value
end
-- Actions if there is a large (greater than or equal to 100,000) transclusion count
function p.risk(frame)
return_value = "risk"
else
local count = _fetch(frame)
if count and count >= 100000 then return_value = "risk" end
end
return return_value
end
function p.text(frame, count)
-- Only show the information about how this template gets updated if someone
-- is actually editing the page and maybe trying to update the count.
local bot_text = (frame:preprocess("{{REVISIONID}}") == "") and "\n\n----\n'''Preview message''': Transclusion count updated automatically ([[Template:High-use/doc#Technical details|see documentation]])." or ''
else
end
end
local title = mw.title.getCurrentTitle()
if title.subpageText == "doc" or title.subpageText == "sandbox" then
title = title.basePageTitle
end
local systemMessages = frame.args['system']
if frame.args['system'] == '' then
systemMessages = nil
end
-- This retrieves the project URL automatically to simplify localiation.
local templateCount = ('on [https://linkcount.toolforge.org/index.php?project=%s&page=%s %s pages]'):format(
mw.title.getCurrentTitle():fullUrl():gsub('//(.-)/.*', '%1'),
mw.uri.encode(title.fullText), p.num(frame, count))
local used_on_text = "'''This " .. (mw.title.getCurrentTitle().namespace == 828 and "Lua module" or "template") .. ' is used ';
if systemMessages then
used_on_text = used_on_text .. systemMessages ..
((count and count > 2000) and (",''' and " .. templateCount) or ("'''"))
else
used_on_text = used_on_text .. templateCount .. "'''"
end
local sandbox_text = ("%s's [[%s/sandbox|/sandbox]] or [[%s/testcases|/testcases]] subpages, or in your own [[%s]]. "):format(
(mw.title.getCurrentTitle().namespace == 828 and "module" or "template"),
title.fullText, title.fullText,
mw.title.getCurrentTitle().namespace == 828 and "Module:Sandbox|module sandbox" or "Wikipedia:User pages#SUB|user subpage"
local infoArg = frame.args["info"] ~= "" and frame.args["info"]
if (systemMessages or frame.args[1] == "risk" or (count and count >= 100000) ) then
local info = systemMessages and '.<br/>Changes to it can cause immediate changes to the Wikipedia user interface.' or '.'
if infoArg then
info = info .. "<br />" .. infoArg
end
sandbox_text = info .. '<br /> To avoid major disruption' ..
(count and count >= 100000 and ' and server load' or '') ..
', any changes should be tested in the ' .. sandbox_text ..
'The tested changes can be added to this page in a single edit. '
else
sandbox_text = (infoArg and ('.<br />' .. infoArg .. ' C') or ' and c') ..
'hanges may be widely noticed. Test changes in the ' .. sandbox_text
end
local discussion_text = systemMessages and 'Please discuss changes ' or 'Consider discussing changes '
if frame.args["2"] and frame.args["2"] ~= "" and frame.args["2"] ~= "yes" then
discussion_text = string.format("%sat [[%s]]", discussion_text, frame.args["2"])
else
discussion_text = string.format("%son the [[%s|talk page]]", discussion_text, title.talkPageTitle.fullText )
end
return used_on_text .. sandbox_text .. discussion_text .. " before implementing them." .. bot_text
end
function p.main(frame)
local count = nil
else
end
local image = "[[File:Ambox warning yellow.svg|40px|alt=Warning|link=]]"
local type_param = "style"
local epilogue = ''
if frame.args['system'] and frame.args['system'] ~= '' then
image = "[[File:Ambox important.svg|40px|alt=Warning|link=]]"
type_param = "content"
local nocat = frame:getParent().args['nocat'] or frame.args['nocat']
local categorise = (nocat == '' or not yesno(nocat))
if categorise then
epilogue = frame:preprocess('{{Sandbox other||{{#switch:{{#invoke:Effective protection level|{{#switch:{{NAMESPACE}}|File=upload|#default=edit}}|{{FULLPAGENAME}}}}|sysop|templateeditor|interfaceadmin=|#default=[[Category:Pages used in system messages needing protection]]}}}}')
end
elseif (frame.args[1] == "risk" or (count and count >= 100000)) then
image = "[[File:Ambox warning orange.svg|40px|alt=Warning|link=]]"
end
if frame.args["form"] == "editnotice" then
return frame:expandTemplate{
title = 'editnotice',
args = {
["image"] = image,
["text"] = p.text(frame, count),
["expiry"] = (frame.args["expiry"] or "")
} .. epilogue
else
return require('Module:Message box').main('ombox', {
type = type_param,
image = image,
text = p.text(frame, count),
expiry = (frame.args["expiry"] or "")
}) .. epilogue
end
end
return p
