Module:Transcluder
Revision as of 13:20, 8 December 2021 by w>Sophivorus (Update to latest)
Lua error: expandTemplate: template loop detected.
local p = {}
-- Helper function to test for truthy and falsy values
-- @todo Somehow internationalize it
local function truthy(value)
if not value or value == '' or value == 0 or value == '0' or value == 'false' or value == 'no' or value == 'non' then
return false
end
return true
end
-- Helper function to match from a list of regular expressions
-- Like so: match pre..list[1]..post or pre..list[2]..post or ...
local function matchAny(text, pre, list, post, init)
local match = {}
for i = 1, #list do
match = { mw.ustring.match(text, pre .. list[i] .. post, init) }
if match[1] then return unpack(match) end
end
return nil
end
-- Like matchAny but for Category/File links with less overhead
local function matchAnyLink(text, list)
local match
for _, v in ipairs(list) do
match = string.match(text, '%[%[%s*' .. v .. '%s*:.*%]%]')
if match then break end
end
return match
end
-- Helper function to escape a string for use in regexes
local function escapeString(str)
return string.gsub(str, '[%^%$%(%)%.%[%]%*%+%-%?%%]', '%%%0')
end
-- Helper function to remove a string from a text
local function removeString(text, str)
local pattern = escapeString(str)
if #pattern > 9999 then -- strings longer than 10000 bytes can't be put into regexes
pattern = escapeString(mw.ustring.sub(str, 1, 999)) .. '.-' .. escapeString(mw.ustring.sub(str, -999))
end
return string.gsub(text, pattern, '')
end
-- Helper function to convert a comma-separated list of numbers or min-max ranges into a list of booleans
-- @param flags Comma-separated list of numbers or min-max ranges, for example '1,3-5'
-- @return Map from integers to booleans, for example {1=true,2=false,3=true,4=true,5=true}
-- @return Boolean indicating whether the flags should be treated as a blacklist or not
local function parseFlags(value)
local flags = {}
local blacklist = false
if not value then return nil, false end
if type(value) == 'number' then
if value < 0 then
value = -value
blacklist = true
end
flags = { [value] = true }
elseif type(value) == 'string' then
if string.sub(value, 1, 1) == '-' then
blacklist = true
value = string.sub(value, 2)
end
local ranges = mw.text.split(value, ',') -- split ranges: '1,3-5' to {'1','3-5'}
for _, range in pairs(ranges) do
range = mw.text.trim(range)
local min, max = mw.ustring.match(range, '^(%d+)%s*[-–—]%s*(%d+)$') -- '3-5' to min=3 max=5
if not max then min, max = string.match(range, '^((%d+))$') end -- '1' to min=1 max=1
if max then
for i = min, max do flags[i] = true end
else
flags[range] = true -- if we reach this point, the string had the form 'a,b,c' rather than '1,2,3'
end
end
-- List has the form { [1] = false, [2] = true, ['c'] = false }
-- Convert it to { [1] = true, [2] = true, ['c'] = true }
-- But if ANY value is set to false, treat the list as a blacklist
elseif type(value) == 'table' then
for i, v in pairs(value) do
if v == false then blacklist = true end
flags[i] = true
end
end
return flags, blacklist
end
-- Helper function to see if a value matches any of the given flags
local function matchFlag(value, flags)
if not value then return false end
value = tostring(value)
local lang = mw.language.getContentLanguage()
for flag in pairs(flags) do
if value == tostring(flag)
or lang:lcfirst(value) == flag
or lang:ucfirst(value) == flag
or ( not tonumber(flag) and mw.ustring.match(value, flag) ) then
return true
end
end
end
-- Helper function to convert template arguments into an array of options fit for get()
local function parseArgs(frame)
local args = {}
for key, value in pairs(frame:getParent().args) do args[key] = value end
for key, value in pairs(frame.args) do args[key] = value end -- args from Lua calls have priority over parent args from template
return args
end
-- Error handling function
-- Throws a Lua error or returns an empty string if error reporting is disabled
local function throwError(key, value)
local TNT = require('Module:TNT')
local ok, message = pcall(TNT.format, 'I18n/Module:Transcluder.tab', 'error-' .. key, value)
if not ok then message = key end
error(message, 2)
end
-- Returns a wiki friendly error or an empty string if error reporting is disabled
local function getError(key, value)
message = mw.html.create('div'):addClass('error'):wikitext(message)
return message
end
-- Helper function to get the local name of a namespace and all its aliases
-- @param name Canonical name of the namespace, for example 'File'
-- @return Local name of the namespace and all aliases, for example {'File','Image','Archivo','Imagen'}
local function getNamespaces(name)
local namespaces = mw.clone(mw.site.namespaces[name].aliases) -- Clone because https://en.wikipedia.org/w/index.php?diff=1056921358
table.insert(namespaces, mw.site.namespaces[name].name)
table.insert(namespaces, mw.site.namespaces[name].canonicalName)
return namespaces
end
-- Get the page wikitext, following redirects
-- Also returns the page name, or the target page name if a redirect was followed, or false if no page was found
-- For file pages, returns the content of the file description page
local function getText(page, noFollow)
local title = mw.title.new(page)
if not title then return false, false end
local target = title.redirectTarget
if target and not noFollow then title = target end
local text = title:getContent()
if not text then return false, title.prefixedText end
-- Remove <noinclude> tags
text = string.gsub(text, '<[Nn][Oo][Ii][Nn][Cc][Ll][Uu][Dd][Ee]>.-</[Nn][Oo][Ii][Nn][Cc][Ll][Uu][Dd][Ee]>', '') -- remove noinclude bits
-- Keep <onlyinclude> tags
if string.find(text, '[Oo][Nn][Ll][Yy][Ii][Nn][Cc][Ll][Uu][Dd][Ee]') then -- avoid expensive search if possible
text = text
:gsub('</[Oo][Nn][Ll][Yy][Ii][Nn][Cc][Ll][Uu][Dd][Ee]>.-<[Oo][Nn][Ll][Yy][Ii][Nn][Cc][Ll][Uu][Dd][Ee]>', '') -- remove text between onlyinclude sections
:gsub('^.-<[Oo][Nn][Ll][Yy][Ii][Nn][Cc][Ll][Uu][Dd][Ee]>', '') -- remove text before first onlyinclude section
:gsub('</[Oo][Nn][Ll][Yy][Ii][Nn][Cc][Ll][Uu][Dd][Ee]>.*', '') -- remove text after last onlyinclude section
end
return text, title.prefixedText
end
-- Get the requested files from the given wikitext.
-- @param text Required. Wikitext to parse.
-- @param flags Range of files to return, for example 2 or '1,3-5'. Omit to return all files.
-- @return Sequence of strings containing the wikitext of the requested files.
-- @return Original wikitext minus requested files.
local function getFiles(text, flags)
local files = {}
local flags, blacklist = parseFlags(flags)
local fileNamespaces = getNamespaces('File')
local name
local count = 0
for file in string.gmatch(text, '%b[]') do
if matchAnyLink(file, fileNamespaces) then
name = string.match(file, '%[%[[^:]-:([^]|]+)')
count = count + 1
if not blacklist and ( not flags or flags[count] or matchFlag(name, flags) )
or blacklist and flags and not flags[count] and not matchFlag(name, flags) then
table.insert(files, file)
else
text = removeString(text, file)
end
end
end
return files, text
end
-- Get the requested tables from the given wikitext.
-- @param flags Range of tables to return, for example 2 or '1,3-5'. Omit to return all tables.
-- @return Sequence of strings containing the wikitext of the requested tables.
-- @return Original wikitext minus requested tables.
local function getTables(text, flags)
local tables = {}
local id
local count = 0
for t in string.gmatch('\n' .. text, '\n%b{}') do
if string.sub(t, 1, 3) == '\n{|' then
id = string.match(t, '\n{|[^\n]-id%s*=%s*["\']?([^"\'\n]+)["\']?[^\n]*\n')
count = count + 1
if not blacklist and ( not flags or flags[count] or flags[id] )
or blacklist and flags and not flags[count] and not flags[id] then
table.insert(tables, t)
else
text = removeString(text, t)
end
end
end
return tables, text
end
-- Get the requested templates from the given wikitext.
-- @param flags Range of templates to return, for example 2 or '1,3-5'. Omit to return all templates.
-- @return Sequence of strings containing the wikitext of the requested templates.
-- @return Original wikitext minus requested templates.
local function getTemplates(text, flags)
local templates = {}
local name
local count = 0
for template in string.gmatch(text, '{%b{}}') do
if string.sub(template, 1, 3) ~= '{{#' then -- skip parser functions like #if
name = mw.text.trim( string.match(template, '{{([^}|\n]+)') ) -- get the template name
count = count + 1
table.insert(templates, template)
else
text = removeString(text, template)
end
end
end
return templates, text
end
-- Get the requested template parameters from the given wikitext.
-- @param flags Range of parameters to return, for example 2 or '1,3-5'. Omit to return all parameters.
-- @return Map from parameter name to value, NOT IN THE ORIGINAL ORDER
-- @return Original wikitext minus requested parameters.
local function getParameters(text, flags)
local parameters = {}
local params, count, parts, key, value
params = string.match(template, '{{[^|}]-|(.+)}}')
if params then
count = 0
-- Temporarily replace pipes in subtemplates, tables and links to avoid chaos
for subtemplate in string.gmatch(params, '%b{}') do
params = string.gsub(params, escapeString(subtemplate), string.gsub(string.gsub(subtemplate, '%%', '%%%%'), '|', '@@@') )
end
for link in string.gmatch(params, '%b[]') do
params = string.gsub(params, escapeString(link), string.gsub(link, '|', '@@@') )
end
for parameter in mw.text.gsplit(params, '|') do
parts = mw.text.split(parameter, '=')
key = mw.text.trim(parts[1])
value = table.concat(parts, '=', 2)
if value == '' then
value = key
count = count + 1
key = count
else
value = mw.text.trim(value)
end
value = string.gsub(value, '@@@', '|')
if not blacklist and ( not flags or matchFlag(key, flags) )
or blacklist and flags and not matchFlag(key, flags) then
parameters[key] = value
else
text = removeString(text, parameter)
end
end
end
end
return parameters, text
end
-- Get the requested lists from the given wikitext.
-- @param flags Range of lists to return, for example 2 or '1,3-5'. Omit to return all lists.
-- @return Sequence of strings containing the wikitext of the requested lists.
-- @return Original wikitext minus requested lists.
local function getLists(text, flags)
local lists = {}
local count = 0
for list in string.gmatch('\n' .. text .. '\n\n', '\n([*#].-)\n[^*#]') do
count = count + 1
if not blacklist and ( not flags or flags[count] )
or blacklist and flags and not flags[count] then
table.insert(lists, list)
else
text = removeString(text, list)
end
end
return lists, text
end
-- Get the requested paragraphs from the given wikitext.
-- @param flags Range of paragraphs to return, for example 2 or '1,3-5'. Omit to return all paragraphs.
-- @return Sequence of strings containing the wikitext of the requested paragraphs.
-- @return Original wikitext minus requested paragraphs.
local function getParagraphs(text, flags)
local paragraphs = {}
-- Remove non-paragraphs
local elements
local temp = '\n' .. text .. '\n'
elements, temp = getLists(temp, 0) -- remove lists
elements, temp = getFiles(temp, 0) -- remove files
temp = mw.text.trim((temp
:gsub('\n%b{}\n', '\n%0\n') -- add spacing between tables and block templates
:gsub('\n%b{}\n', '\n') -- remove tables and block templates
:gsub('\n==+[^=]+==+\n', '\n') -- remove section titles
-- Assume that anything remaining is a paragraph
local count = 0
for paragraph in mw.text.gsplit(temp, '\n\n+') do
if mw.text.trim(paragraph) ~= '' then
count = count + 1
table.insert(paragraphs, paragraph)
else
text = removeString(text, paragraph)
end
end
end
return paragraphs, text
end
-- Get the requested categories from the given wikitext.
-- @param flags Range of categories to return, for example 2 or '1,3-5'. Omit to return all categories.
-- @return Sequence of strings containing the wikitext of the requested categories.
-- @return Original wikitext minus requested categories.
local function getCategories(text, flags)
local categories = {}
local categoryNamespaces = getNamespaces('Category')
local name
local count = 0
for category in string.gmatch(text, '%b[]') do
if matchAnyLink(category, categoryNamespaces) then
name = string.match(category, '%[%[[^:]-:([^]|]+)')
count = count + 1
table.insert(categories, category)
else
text = removeString(text, category)
end
end
end
return categories, text
end
-- Get the requested references from the given wikitext.
-- @param flags Range of references to return, for example 2 or '1,3-5'. Omit to return all references.
-- @return Sequence of strings containing the wikitext of the requested references.
-- @return Original wikitext minus requested references.
local function getReferences(text, flags)
local references = {}
-- Remove all references, including citations, when 0 references are requested
-- This is kind of hacky but currently necessary because the rest of the code
-- doesn't remove citations like <ref name="Foo" /> if Foo is defined elsewhere
if flags and not truthy(flags) then
text = string.gsub(text, '<%s*[Rr][Ee][Ff][^>/]*>.-<%s*/%s*[Rr][Ee][Ff]%s*>', '')
text = string.gsub(text, '<%s*[Rr][Ee][Ff][^>/]*/%s*>', '')
return references, text
end
local name
local count = 0
for reference in string.gmatch(text, '<%s*[Rr][Ee][Ff][^>/]*>.-<%s*/%s*[Rr][Ee][Ff]%s*>') do
name = string.match(reference, '<%s*[Rr][Ee][Ff][^>]*name%s*=%s*["\']?([^"\'>/]+)["\']?[^>]*%s*>')
count = count + 1
table.insert(references, reference)
else
text = removeString(text, reference)
if name then
for citation in string.gmatch(text, '<%s*[Rr][Ee][Ff][^>]*name%s*=%s*["\']?' .. escapeString(name) .. '["\']?[^/>]*/%s*>') do
text = removeString(text, citation)
end
end
end
end
end
-- Get the lead section from the given wikitext.
-- @return Wikitext of the lead section.
local function getLead(text)
text = string.gsub('\n' .. text, '\n==.*', '')
text = mw.text.trim(text)
if not text then return throwError('lead-empty') end
return text
end
-- Get the requested sections from the given wikitext.
-- @param flags Range of sections to return, for example 2 or '1,3-5'. Omit to return all references.
-- @return Sequence of strings containing the wikitext of the requested sections.
-- @return Original wikitext minus requested sections.
local function getSections(text, flags)
local sections = {}
local count = 0
local prefix, section, suffix
for title in string.gmatch('\n' .. text .. '\n==', '\n==+%s*([^=]+)%s*==+') do
count = count + 1
prefix, section, suffix = string.match('\n' .. text .. '\n==', '\n()==+%s*' .. escapeString(title) .. '%s*==+(.-)()\n==')
if not blacklist and ( not flags or flags[count] or matchFlag(title, flags) )
or blacklist and flags and not flags[count] and not matchFlag(title, flags) then
sections[title] = section
else
text = string.sub(text, 1, prefix) .. string.sub(text, suffix)
text = string.gsub(text, '\n?==$', '') -- remove the trailing \n==
end
end
return sections, text
end
-- Get the requested section from the given wikitext (including subsections).
-- @param section Required. Title of the section to get (in wikitext), for example 'History' or 'History of [[Athens]]'.
-- @return Wikitext of the requested section.
local function getSection(text, section)
section = mw.text.trim(section)
local escapedSection = escapeString(section)
-- First check if the section title matches a <section> tag
if string.find(text, '<%s*[Ss]ection%s+begin%s*=%s*["\']?%s*' .. escapedSection .. '%s*["\']?%s*/>') then -- avoid expensive search if possible
text = mw.text.trim((text
:gsub('<%s*[Ss]ection%s+end=%s*["\']?%s*'.. escapedSection ..'%s*["\']?%s*/>.-<%s*[Ss]ection%s+begin%s*=%s*["\']?%s*' .. escapedSection .. '%s*["\']?%s*/>', '') -- remove text between section tags
:gsub('^.-<%s*[Ss]ection%s+begin%s*=%s*["\']?%s*' .. escapedSection .. '%s*["\']?%s*/>', '') -- remove text before first section tag
:gsub('<%s*[Ss]ection%s+end=%s*["\']?%s*'.. escapedSection ..'%s*["\']?%s*/>.*', '') -- remove text after last section tag
if text == '' then return throwError('section-tag-empty', section) end
return text
end
local level, text = string.match('\n' .. text .. '\n', '\n(==+)%s*' .. escapedSection .. '%s*==.-\n(.*)')
if not text then return throwError('section-not-found', section) end
local nextSection = '\n==' .. string.rep('=?', #level - 2) .. '[^=].*'
text = string.gsub(text, nextSection, '') -- remove later sections with headings at this level or higher
if text == '' then return throwError('section-empty', section) end
return text
end
-- Replace the first call to each reference defined outside of the text for the full reference, to prevent undefined references
-- Then prefix the page title to the reference names to prevent conflicts
-- that is, replace <ref name="Foo"> for <ref name="Title of the article Foo">
-- and also <ref name="Foo" /> for <ref name="Title of the article Foo" />
-- also remove reference groups: <ref name="Foo" group="Bar"> for <ref name="Title of the article Foo">
-- and <ref group="Bar"> for <ref>
-- @todo The current regex may fail in cases with both kinds of quotes, like <ref name="Darwin's book">
local function fixReferences(text, page, full)
if not full then full = getText(page) end
local refNames = {}
local refName
local refBody
local position = 1
while position < mw.ustring.len(text) do
refName, position = mw.ustring.match(text, '<%s*[Rr][Ee][Ff][^>]*name%s*=%s*["\']?([^"\'>]+)["\']?[^>]*/%s*>()', position)
if refName then
refName = mw.text.trim(refName)
if not refNames[refName] then -- make sure we process each ref name only once
table.insert(refNames, refName)
refName = escapeString(refName)
refBody = mw.ustring.match(text, '<%s*[Rr][Ee][Ff][^>]*name%s*=%s*["\']?%s*' .. refName .. '%s*["\']?[^>/]*>.-<%s*/%s*[Rr][Ee][Ff]%s*>')
if not refBody then -- the ref body is not in the excerpt
refBody = mw.ustring.match(full, '<%s*[Rr][Ee][Ff][^>]*name%s*=%s*["\']?%s*' .. refName .. '%s*["\']?[^/>]*>.-<%s*/%s*[Rr][Ee][Ff]%s*>')
if refBody then -- the ref body was found elsewhere
text = mw.ustring.gsub(text, '<%s*[Rr][Ee][Ff][^>]*name%s*=%s*["\']?%s*' .. refName .. '%s*["\']?[^>]*/?%s*>', mw.ustring.gsub(refBody, '%%', '%%%%'), 1)
end
end
end
else
position = mw.ustring.len(text)
end
end
page = string.gsub(page, '"', '') -- remove any quotation marks from the page title
text = mw.ustring.gsub(text, '<%s*[Rr][Ee][Ff][^>]*name%s*=%s*["\']?([^"\'>/]+)["\']?[^>/]*(/?)%s*>', '<ref name="' .. page .. ' %1"%2>')
text = mw.ustring.gsub(text, '<%s*[Rr][Ee][Ff]%s*group%s*=%s*["\']?[^"\'>/]+["\']%s*>', '<ref>')
return text
end
-- Replace the bold title or synonym near the start of the page by a link to the page
local function linkBold(text, page)
local position = mw.ustring.find(text, "'''" .. lang:ucfirst(page) .. "'''", 1, true) -- look for "'''Foo''' is..." (uc) or "A '''foo''' is..." (lc)
or mw.ustring.find(text, "'''" .. lang:lcfirst(page) .. "'''", 1, true) -- plain search: special characters in page represent themselves
if position then
local length = mw.ustring.len(page)
text = mw.ustring.sub(text, 1, position + 2) .. "[[" .. mw.ustring.sub(text, position + 3, position + length + 2) .. "]]" .. mw.ustring.sub(text, position + length + 3, -1) -- link it
else -- look for anything unlinked in bold, assumed to be a synonym of the title (e.g. a person's birth name)
text = mw.ustring.gsub(text, "()'''(.-'*)'''", function(a, b)
if not mw.ustring.find(b, "%[") and not mw.ustring.find(b, "%{") then -- if not wikilinked or some weird template
return "'''[[" .. page .. "|" .. b .. "]]'''" -- replace '''Foo''' by '''[[page|Foo]]'''
else
return nil -- instruct gsub to make no change
end
end, 1) -- "end" here terminates the anonymous replacement function(a, b) passed to gsub
end
return text
end
-- Remove non-free files.
-- @param text Required. Wikitext to clean.
-- @return Clean wikitext.
local function removeNonFreeFiles(text)
local fileName
local fileDescription
local frame = mw.getCurrentFrame()
fileName = 'File:' .. string.match(file, '%[%[[^:]-:([^]|]+)')
fileDescription, fileName = getText(fileName)
if fileName then
if not fileDescription or fileDescription == '' then
fileDescription = frame:preprocess('{{' .. fileName .. '}}') -- try Commons
end
if fileDescription and string.match(fileDescription, '[Nn]on%-free') then
end
end
end
end
return text
end
-- Remove any self links
local function removeSelfLinks(text)
local page = escapeString(mw.title.getCurrentTitle().prefixedText)
text = text
:gsub('%[%[(' .. lang:ucfirst(page) .. ')%]%]', '%1')
:gsub('%[%[(' .. lang:lcfirst(page) .. ')%]%]', '%1')
:gsub('%[%[' .. lang:ucfirst(page) .. '|([^]]+)%]%]', '%1')
:gsub('%[%[' .. lang:lcfirst(page) .. '|([^]]+)%]%]', '%1')
return text
end
-- Remove all wikilinks
local function removeLinks(text)
text = text
:gsub('%[%[[^|]+|([^]]+)%]%]', '%1')
:gsub('%[%[([^]]+)%]%]', '%1')
return text
end
-- Remove HTML comments
local function removeComments(text)
text = string.gsub(text, '<!%-%-.-%-%->', '')
return text
end
-- Remove behavior switches, such as __NOTOC__
local function removeBehaviorSwitches(text)
text = string.gsub(text, '__[A-Z]+__', '')
return text
end
-- Remove bold text
local function removeBold(text)
text = string.gsub(text, "'''", '')
return text
end
-- Main function for modules
local function get(page, options)
if not options then options = {} end
if not page then return throwError('no-page') end
page = mw.text.trim(page)
if page == '' then return throwError('no-page') end
local page, hash, section = string.match(page, '([^#]+)(#?)([^#]*)')
local text, page = getText(page, options.noFollow)
if not text then return throwError('page-not-found', page) end
local full = text -- save the full text for fixReferences below
if truthy(section) then
text = getSection(text, section)
elseif truthy(hash) then
text = getLead(text)
end
-- Keep only the requested elements
local elements
if options.only then
if options.only == 'sections' then elements = getSections(text, options.sections) end
if options.only == 'lists' then elements = getLists(text, options.lists) end
if options.only == 'files' then elements = getFiles(text, options.files) end
if options.only == 'tables' then elements = getTables(text, options.tables) end
if options.only == 'templates' then elements = getTemplates(text, options.templates) end
if options.only == 'parameters' then elements = getParameters(text, options.parameters) end
if options.only == 'paragraphs' then elements = getParagraphs(text, options.paragraphs) end
if options.only == 'categories' then elements = getCategories(text, options.categories) end
if options.only == 'references' then elements = getReferences(text, options.references) end
text = ''
if elements then
for key, element in pairs(elements) do
text = text .. '\n' .. element .. '\n'
end
end
end
-- Filter the requested elements
if options.sections and options.only ~= 'sections' then elements, text = getSections(text, options.sections) end
if options.lists and options.only ~= 'lists' then elements, text = getLists(text, options.lists) end
if options.files and options.only ~= 'files' then elements, text = getFiles(text, options.files) end
if options.tables and options.only ~= 'tables' then elements, text = getTables(text, options.tables) end
if options.templates and options.only ~= 'templates' then elements, text = getTemplates(text, options.templates) end
if options.parameters and options.only ~= 'parameters' then elements, text = getParameters(text, options.parameters) end
if options.paragraphs and options.only ~= 'paragraphs' then elements, text = getParagraphs(text, options.paragraphs) end
if options.categories and options.only ~= 'categories' then elements, text = getCategories(text, options.categories) end
if options.references and options.only ~= 'references' then elements, text = getReferences(text, options.references) end
-- Misc options
if truthy(options.fixReferences) then text = fixReferences(text, page, full) end
if truthy(options.linkBold) and not truthy(section) then text = linkBold(text, page) end
if truthy(options.noBold) then text = removeBold(text) end
if truthy(options.noLinks) then text = removeLinks(text) end
if truthy(options.noSelfLinks) then text = removeSelfLinks(text) end
if truthy(options.noNonFreeFiles) then text = removeNonFreeFiles(text) end
if truthy(options.noBehaviorSwitches) then text = removeBehaviorSwitches(text) end
if truthy(options.noComments) then text = removeComments(text) end
-- Remove multiple newlines left over from removing elements
text = string.gsub(text, '\n\n\n+', '\n\n')
return text
end
-- Main invocation function for templates
local function main(frame)
local args = parseArgs(frame)
local page = args[1]
local ok, text = pcall(get, page, args)
if not ok then return getError(text) end
return frame:preprocess(text)
end
-- Entry points for templates
function p.main(frame) return main(frame) end
-- Entry points for modules
function p.get(page, options) return get(page, options) end
function p.getText(page, noFollow) return getText(page, noFollow) end
function p.getLead(text) return getLead(text) end
function p.getSection(text, section) return getSection(text, section) end
function p.getSections(text, flags) return getSections(text, flags) end
function p.getParagraphs(text, flags) return getParagraphs(text, flags) end
function p.getParameters(text, flags) return getParameters(text, flags) end
function p.getCategories(text, flags) return getCategories(text, flags) end
function p.getReferences(text, flags) return getReferences(text, flags) end
function p.getTemplates(text, flags) return getTemplates(text, flags) end
function p.getTables(text, flags) return getTables(text, flags) end
function p.getLists(text, flags) return getLists(text, flags) end
function p.getFiles(text, flags) return getFiles(text, flags) end
function p.getError(message, value) return getError(message, value) end
-- Expose handy methods
function p.truthy(value) return truthy(value) end
function p.parseArgs(frame) return parseArgs(frame) end
function p.matchAny(text, pre, list, post, init) return matchAny(text, pre, list, post, init) end
function p.matchFlag(value, flags) return matchFlag(value, flags) end
function p.getNamespaces(name) return getNamespaces(name) end
function p.removeBold(text) return removeBold(text) end
function p.removeLinks(text) return removeLinks(text) end
function p.removeSelfLinks(text) return removeSelfLinks(text) end
function p.removeNonFreeFiles(text) return removeNonFreeFiles(text) end
function p.removeBehaviorSwitches(text) return removeBehaviorSwitches(text) end
function p.removeComments(text) return removeComments(text) end
return p
