Tarkin
Setup
1. Locate Fire Extinguisher
2. Main Power Switch
Tarkin's chiller switch
3. Chiller switch
4. Locate E-STOP button
Important Terms
Machine bed
Material
Lightburn
Workspace
Job
User origin
Vector Cutting
Vector Engraving
Rastering
Fill
Focusing
Focus tool
Origins
Absolute coords
User origin
Camera-placed absolute coords
These all produce similar burns, but the top and bottom settings attempts waste runtime
Rastering
MAX RASTER
Types of Rastering:
FILL
GRAYSCALE 2D
Depth Map
DITHER/HALFTONING 2D
Rastering with Focus+
Overburn apparent on cleaning
0.1mm, too close
Shutdown
Turn off main power
Turn off chiller
Order is NOT important
Usable
Plywood quality and "Patches"
Prohibited
NO PVC
NO Polycarbonate
NO PINE OVER 3/8"
Pine- as either lumber or cheap plywood- is very resinous, more difficult to cut, and much more prone to form a coal that smolders or catches fire during or after cutting. While Tarkin has been uniquely successful at cutting wood and plywood well over 1/2" (6mm), pine in any form has consistently failed in flames in anything past 3/8" (9mm) and is prohibited. Spruce and fir are not pine.
NO METAL
NO FOOD
Copper Wire Flame Test
Machine Errors
Causes:
WATER PROT
SYS ALARM, MACHINE PROTECTED
Likely causes:
FRAME SLOP
Current Quirks
Table shifting when moving Z
Fixed air assist
Expected resolution
Limit on Y size
Drive Faulting
Cone clipping
