CoWorking
Revision as of 03:24, 30 September 2021 by Jon (talk | contribs) (Created page with "= Private Offices = Any member can work from tables in the Lounge or Classroom, as long as they are available (the Classroom is often reserved for classes). A limited numbe...")
Private Offices
Any member can work from tables in the Lounge or Classroom, as long as they are available (the Classroom is often reserved for classes). A limited number of restricted-access cubicles are available in a restricted access office.
Pricing
coworking cubicle
Benefits
  • 6' x 6' cubicle, individual lighting as well as overhead lighting.
  • Cubicles are dedicated, not shared.
  • Cubicle walls are provided.
  • Each cubicle has two wired ethernet ports and outlets
  • VOIP can be set up on the cubicle's second wired ethernet port.
  • The private office area is secured so only office holders and Asmbly management have access..
  • Shop facilities available around the clock. Time can be scheduled in advance for laser cutter and 3-D printers.
  • One Asmbly Makerspace membership is included in the rates above.
For More Information
We are located at 9701 Dessau Road, Building 3, Suite 304, Austin TX 78754.
Or you may contact the Facilities Director To learn more about Asmbly Makerspace, start here.
