Miller Multimatic 220 Welder
Asmbly has two Multimatic 220 multi-process welders. These have both MIG and AC/DC TIG capabilities, each of which has its own prerequisite class. One's owned by Asmbly, the other's hosted by Jon.
Members must complete the MIG Welding Class before using this tool
Members must complete the TIG Welding Class before using this tool
- Always wear appropriate personal protective equipment (PPE), including welding gloves, a welding helmet with appropriate shade, flame-resistant clothing, and safety boots.
- Ensure proper ventilation when welding to prevent exposure to fumes and gases.
- Keep flammable materials away from the welding area.
- Do not weld on containers that have held combustibles unless properly prepared.
- Always disconnect power before performing maintenance.
- MIG Welding Class is required to use this tool.
- Do not touch live electrical parts; always assume the workplace and electrode are electrically live.
- Always check that the machine is properly grounded and all cables are securely connected before operation
- Ensure the ground clamp is securely attached to the workpiece.
- Use proper shielding gas to minimize exposure to harmful fumes.
- Keep all covers and panels in place during operation.
- Avoid working in wet or damp environments when operating the equipment.
- Maintain a clean and organized workspace
- Follow safety protocols to minimize risk of injury to yourself or others
- Report any equipment malfunctions
The Miller Multimatic 220 AC/DC is a versatile multi-process welder capable of MIG, Stick, and TIG welding, suitable for small fabrication shops, maintenance, and hobbyist applications. It supports both 120V and 240V power inputs for various work environments.
Material Capacity
- Mild Steel 24 ga. - 3/8 in. (MIG)
- Mild Steel 24 ga. - 1/4 in. (TIG)
- Aluminum 24 ga. - 1/4 in. (TIG)
- Always clean up spatter and debris from the work area.
- Store consumables properly to prevent contamination.
- Clean the welding nozzle regularly to prevent spatter buildup.
- Replace contact tips as needed.
- Inspect and clean drive rolls to ensure proper wire feeding.
- Store hoses, cables, and attachments appropriately.
| Issue | Definition | Possible Causes | Solution |
| No arc start | Poor ground connection | Ensure ground clamp is attached securely | |
| Excessive spatter | Scattering of molten metal particles that cool to solid form near weld bead. | Incorrect voltage/wire speed.
Adjust settings per material thickness
| Porosity in weld | Small cavities or holes resulting from gas pockets in weld metal. |
| Wire feeding issues | Drive roll slippage | Check and clean drive rolls | |
| Incomplete Fusion | Failure of weld metal to fuse completely with base metal or a preceding weld bead. | *Insufficient heat input.
| Lack of Penetration | Shallow fusion between weld metal and base metal. |
| Excessive Penetration | Weld metal melts through the base metal and hangs underneath the weld. | Excessive heat input. |
| Burn-Through | Weld metal melting completely through base metal resulting in holes where no
metal remains. |
| Waviness Of Bead | Weld metal that is not parallel and does not cover joint formed by base metal. | Unsteady hand. |
| Distortion | Contraction of weld metal during welding that forces base metal to move. | Excessive heat input. |
