Equipment Template
<INSERT PHOTO OF EQUIPMENT>
Etiquette (if relevant)
Example:
e.g. bulk lubricant or cleaning supplies
Tool Use
  • What to clean
  • How to clean
  • Where to dispose of waste
Example for Miter Saw:
  1. Brush off top surface
  2. Brush around machine
  4. Sweep floor
SIG Information (if relevant)
Common Projects
