Laguna TFlux 5 Dust Collector
- Users Manual
- iVac Pro System Guide
- iVac Blast Gate User Manual
iVac System Addresses
| Table Saw 2 | 000100 | A | |
| Table Saw 1 ICS51230 | 010111 | C | |
Usage Notes
- The dust collector will automatically turn on and off. It is still the users responsibility to make sure the dust collector is on before using a woodshop tool.
- When turning on a tool when the dust collector is off, please give it a 10 seconds or so for the dust collector to spin up before using the tool.
- When changing the dust bin:
- Please make sure other users are aware and do not use any tools
- Turn the switch on the yellow box on the dust collector to "off" instead of "auto".
- Return the mode to "auto" after the bin has been emptied.
| Mode | LED |
| Standby | LED flases every 4 seconds |
| On | LED on |
| 8 minute off timer | LED flashes 2x or 5x per second |
Implementation
The daisy chain setup is plugged in high above the router table.
Troubleshotting Steps for Blast Gates
- Verify tool sensor and blast gate are set to "AUTO"
- Verify tool sensor has red light when tool is powered on
- If not, verify tool sensor is plugged in
- Check outlet is working
- Check USB port is working
- Swap USB power supplies
- If power is good, try adjusting sensitivity setting, verify dip switch settings are correct
- Check if blast gate is opening:
- If the green area is showing, the gate is open
- Disconnect hose, and verify suction is good
- Check for blockages in the hose
- If tool sensor is working, and blast gate is not opening:
- Try changing the blast gate to ON/CLOSED and verify if the gate is opening/closing
- Is the gate making any noise? If so, it may be a mechanical issue with the gate itself
- If not making any noise, check if outlet has power
- If outlet is working, verify gate power supply is working
- check for voltage
- swap power supply with spare from the stewards closet
Troubleshooting Automatic Control
- If a tool is not triggering the dust collector, verify the tool sensor is working correctly.
- verify iVac MSC on dust collector is set to "auto"
- verify tool sensor is set to "auto"
- verify tool sensor LED is lit when the tool is turned on
- If the tool is on system address C, verify iVac switch above router table is activated when the tool is turned on
- There should be a blue led you can see when it is activated
- This iVac switch should be set to auto
- The tool sensor it is connected to should be set to "off-ext"
- Try unplugging both the tool sensor and switch, and plug back in.
- Try turning all tools off, turn automatic control to off, then back to auto.
- If the dust collector is not turning off
- Check iVac MSC LED, if light steadily, it thinks a tool is on
- Verify nothing sneaky a turned on, examples:
- South Bend sander master power enabled, but belt not running
- Drum Sander belt running
- A tool sensor set to "on" instead of "auto"
- Check iVac MSC LED, if blinking at 4x per second, DC should shut off within 8 minutes
