Module:Hatnote
Documentation for this module may be created at Module:Hatnote/doc
-- Module:Hatnote --
-- This module produces hatnote links and links to related articles. It --
-- implements the {{hatnote}} and {{format link}} meta-templates and includes --
-- helper functions for other Lua hatnote modules. --
local libraryUtil = require('libraryUtil')
local checkType = libraryUtil.checkType
local checkTypeForNamedArg = libraryUtil.checkTypeForNamedArg
local mArguments -- lazily initialise [[Module:Arguments]]
local yesno -- lazily initialise [[Module:Yesno]]
local formatLink -- lazily initialise [[Module:Format link]] ._formatLink
local p = {}
-- Helper functions
local curNs = mw.title.getCurrentTitle().namespace
p.missingTargetCat =
--Default missing target category, exported for use in related modules
((curNs == 0) or (curNs == 14)) and
'Articles with hatnote templates targeting a nonexistent page' or nil
local function getArgs(frame)
-- Fetches the arguments from the parent frame. Whitespace is trimmed and
-- blanks are removed.
mArguments = require('Module:Arguments')
return mArguments.getArgs(frame, {parentOnly = true})
end
local function removeInitialColon(s)
-- Removes the initial colon from a string, if present.
return s:match('^:?(.*)')
end
function p.findNamespaceId(link, removeColon)
-- Finds the namespace id (namespace number) of a link or a pagename. This
-- function will not work if the link is enclosed in double brackets. Colons
-- are trimmed from the start of the link by default. To skip colon
-- trimming, set the removeColon parameter to false.
checkType('findNamespaceId', 1, link, 'string')
checkType('findNamespaceId', 2, removeColon, 'boolean', true)
if removeColon ~= false then
link = removeInitialColon(link)
end
local namespace = link:match('^(.-):')
if namespace then
local nsTable = mw.site.namespaces[namespace]
if nsTable then
return nsTable.id
end
end
return 0
end
function p.makeWikitextError(msg, helpLink, addTrackingCategory, title)
-- Formats an error message to be returned to wikitext. If
-- addTrackingCategory is not false after being returned from
-- [[Module:Yesno]], and if we are not on a talk page, a tracking category
-- is added.
checkType('makeWikitextError', 1, msg, 'string')
checkType('makeWikitextError', 2, helpLink, 'string', true)
yesno = require('Module:Yesno')
title = title or mw.title.getCurrentTitle()
-- Make the help link text.
local helpText
if helpLink then
helpText = ' ([[' .. helpLink .. '|help]])'
else
helpText = ''
end
-- Make the category text.
local category
if not title.isTalkPage -- Don't categorise talk pages
and title.namespace ~= 2 -- Don't categorise userspace
and yesno(addTrackingCategory) ~= false -- Allow opting out
then
category = 'Hatnote templates with errors'
category = mw.ustring.format(
'[[%s:%s]]',
mw.site.namespaces[14].name,
category
else
category = ''
end
return mw.ustring.format(
'<strong class="error">Error: %s%s.</strong>%s',
msg,
helpText,
category
end
function p.disambiguate(page, disambiguator)
-- Formats a page title with a disambiguation parenthetical,
-- i.e. "Example" → "Example (disambiguation)".
checkType('disambiguate', 1, page, 'string')
checkType('disambiguate', 2, disambiguator, 'string', true)
disambiguator = disambiguator or 'disambiguation'
return mw.ustring.format('%s (%s)', page, disambiguator)
end
-- Hatnote
-- Produces standard hatnote text. Implements the {{hatnote}} template.
function p.hatnote(frame)
local args = getArgs(frame)
local s = args[1]
if not s then
return p.makeWikitextError(
'no text specified',
'Template:Hatnote#Errors',
args.category
end
return p._hatnote(s, {
extraclasses = args.extraclasses,
selfref = args.selfref
end
function p._hatnote(s, options)
checkType('_hatnote', 1, s, 'string')
checkType('_hatnote', 2, options, 'table', true)
options = options or {}
local inline = options.inline
local hatnote = mw.html.create(inline == 1 and 'span' or 'div')
local extraclasses
if type(options.extraclasses) == 'string' then
extraclasses = options.extraclasses
end
hatnote
:attr('role', 'note')
:addClass(inline == 1 and 'hatnote-inline' or 'hatnote')
:addClass('navigation-not-searchable')
:addClass(extraclasses)
:addClass(options.selfref and 'selfref')
:wikitext(s)
return mw.getCurrentFrame():extensionTag{
name = 'templatestyles', args = { src = 'Module:Hatnote/styles.css' }
} .. tostring(hatnote)
end
return p
