Module:Icon
Documentation for this module may be created at Module:Icon/doc
-- This module implements [[Template:Icon]].
require("Module:No globals")
local yesNo = require("Module:Yesno")
local getArgs = require("Module:Arguments").getArgs
local getPlain = nil
local p = {}
-- Implements [[Template:Icon]]
-- Returns the icon image corresponding to a string (like 'B')
function p._main(args, data)
local inSandbox = yesNo(args.sandbox)
local data_module = 'Module:Icon/data'..(inSandbox and '/sandbox' or '')
data = data or mw.loadData(data_module)
local code = args.class or args[1]
local iconData
if code then
code = code:match('^%s*(.-)%s*$'):lower() -- trim whitespace and put in lower case
iconData = data[code]
end
if not iconData then
iconData = data._DEFAULT
end
return string.format(
'[[File:%s%s%s|%s|class=noviewer|alt=%s]]',
iconData.image,
iconData.tooltip and '|' .. iconData.tooltip or '',
iconData.link == false and '|link=' or '',
args.size or '16x16px',
iconData.alt or ''
end
-- Implements [[Template:Icon link]], a superset of [[Template:Icon]]
-- Returns an icon, plus a suitably formatted wikilink
function p._link(args, data)
args.size = args.size or args.iconsize
local icon = p._main(args, data)
-- If no link given in args[2], default back to [[Template:Icon]]
if not args[2] then
return icon
end
-- Strip wiki markup out of link
getPlain = getPlain or require("Module:Text").Text().getPlain
local link = getPlain(args[2])
local display = args[3] or args[2]
-- italicize display string, if requested
if yesNo(args.i) or yesNo(args.italic) or yesNo(args.italics) then
display = '<i>'..display..'</i>'
end
-- if display is link, just use standard wlink
if link == display then
return icon..' [['..link..']]'
end
return icon..' [['..link..'|'..display..']]'
end
function p.main(frame)
local args = getArgs(frame,{parentFirst=true})
return p._main(args)
end
function p.link(frame)
return p._link(args)
end
return p
