Module:Namespace detect/data
Documentation for this module may be created at Module:Namespace detect/data/doc
-- Namespace detect data --
-- This module holds data for [[Module:Namespace detect]] to be loaded per --
-- page, rather than per #invoke, for performance reasons. --
local cfg = require('Module:Namespace detect/config')
local function addKey(t, key, defaultKey)
if key ~= defaultKey then
t[#t + 1] = key
end
end
-- Get a table of parameters to query for each default parameter name.
-- This allows wikis to customise parameter names in the cfg table while
-- ensuring that default parameter names will always work. The cfg table
-- values can be added as a string, or as an array of strings.
local defaultKeys = {
'main',
'talk',
'other',
'subjectns',
'demospace',
'demopage'
local argKeys = {}
for i, defaultKey in ipairs(defaultKeys) do
argKeys[defaultKey] = {defaultKey}
end
for defaultKey, t in pairs(argKeys) do
local cfgValue = cfg[defaultKey]
local cfgValueType = type(cfgValue)
if cfgValueType == 'string' then
addKey(t, cfgValue, defaultKey)
elseif cfgValueType == 'table' then
for i, key in ipairs(cfgValue) do
end
end
cfg[defaultKey] = nil -- Free the cfg value as we don't need it any more.
end
local function getParamMappings()
-- Returns a table of how parameter names map to namespace names. The keys
-- are the actual namespace names, in lower case, and the values are the
-- possible parameter names for that namespace, also in lower case. The
-- table entries are structured like this:
-- [''] = {'main'},
-- ['wikipedia'] = {'wikipedia', 'project', 'wp'},
local mappings = {}
local mainNsName = mw.site.subjectNamespaces[0].name
mainNsName = mw.ustring.lower(mainNsName)
mappings[mainNsName] = mw.clone(argKeys.main)
mappings['talk'] = mw.clone(argKeys.talk)
for nsid, ns in pairs(mw.site.subjectNamespaces) do
if nsid ~= 0 then -- Exclude main namespace.
local nsname = mw.ustring.lower(ns.name)
local canonicalName = mw.ustring.lower(ns.canonicalName)
mappings[nsname] = {nsname}
if canonicalName ~= nsname then
table.insert(mappings[nsname], canonicalName)
end
for _, alias in ipairs(ns.aliases) do
table.insert(mappings[nsname], mw.ustring.lower(alias))
end
end
end
return mappings
end
return {
argKeys = argKeys,
cfg = cfg,
mappings = getParamMappings()
