Module:Sidebar
Documentation for this module may be created at Module:Sidebar/doc
-- This module implements {{Sidebar}}
require('Module:No globals')
local cfg = mw.loadData('Module:Sidebar/configuration')
local p = {}
local getArgs = require('Module:Arguments').getArgs
Categorizes calling templates and modules with a 'style' parameter of any sort
for tracking to convert to TemplateStyles.
TODO after a long cleanup: Catch sidebars in other namespaces than Template and Module.
TODO would probably want to remove /log and /archive as CS1 does
local function categorizeTemplatesWithInlineStyles(args)
local title = mw.title.getCurrentTitle()
if title.namespace ~= 10 and title.namespace ~= 828 then return '' end
for _, pattern in ipairs (cfg.i18n.pattern.uncategorized_conversion_titles) do
if title.text:match(pattern) then return '' end
end
for key, _ in pairs(args) do
if mw.ustring.find(key, cfg.i18n.pattern.style_conversion) or key == 'width' then
return cfg.i18n.category.conversion
end
end
end
For compatibility with the original {{sidebar with collapsible lists}}
implementation, which passed some parameters through {{#if}} to trim their
whitespace. This also triggered the automatic newline behavior.
-- See ([[meta:Help:Newlines and spaces#Automatic newline]])
local function trimAndAddAutomaticNewline(s)
s = mw.ustring.gsub(s, "^%s*(.-)%s*$", "%1")
if mw.ustring.find(s, '^[#*:;]') or mw.ustring.find(s, '^{|') then
return '\n' .. s
else
return s
end
end
Finds whether a sidebar has a subgroup sidebar.
local function hasSubgroup(s)
if mw.ustring.find(s, cfg.i18n.pattern.subgroup) then
return true
else
return false
end
end
Main sidebar function. Takes the frame, args, and an optional collapsibleClass.
The collapsibleClass is and should be used only for sidebars with collapsible
lists, as in p.collapsible.
function p.sidebar(frame, args, collapsibleClass)
if not args then
args = getArgs(frame)
end
local root = mw.html.create()
local child = args.child and mw.text.trim(args.child) == cfg.i18n.child_yes
root = root:tag('table')
if not child then
root
:addClass(cfg.i18n.class.sidebar)
-- force collapsibleclass to be sidebar-collapse otherwise output nothing
:addClass(collapsibleClass == cfg.i18n.class.collapse and cfg.i18n.class.collapse or nil)
:addClass('nomobile')
:addClass(args.float == cfg.i18n.float_none and cfg.i18n.class.float_none or nil)
:addClass(args.float == cfg.i18n.float_left and cfg.i18n.class.float_left or nil)
:addClass(args.wraplinks ~= cfg.i18n.wrap_true and cfg.i18n.class.wraplinks or nil)
:addClass(args.bodyclass or args.class)
:css('width', args.width or nil)
:cssText(args.bodystyle or args.style)
if args.outertitle then
root
:tag('caption')
:addClass(cfg.i18n.class.outer_title)
:addClass(args.outertitleclass)
:cssText(args.outertitlestyle)
:wikitext(args.outertitle)
end
if args.topimage then
local imageCell = root:tag('tr'):tag('td')
imageCell
:addClass(cfg.i18n.class.top_image)
:addClass(args.topimageclass)
:cssText(args.topimagestyle)
:wikitext(args.topimage)
if args.topcaption then
imageCell
:tag('div')
:addClass(cfg.i18n.class.top_caption)
:cssText(args.topcaptionstyle)
:wikitext(args.topcaption)
end
end
if args.pretitle then
root
:tag('tr')
:tag('td')
:addClass(args.topimage and cfg.i18n.class.pretitle_with_top_image
or cfg.i18n.class.pretitle)
:addClass(args.pretitleclass)
:cssText(args.basestyle)
:cssText(args.pretitlestyle)
:wikitext(args.pretitle)
end
else
root
:addClass(cfg.i18n.class.subgroup)
end
if args.title then
if child then
root
:wikitext(args.title)
else
root
:tag('tr')
:tag('th')
:addClass(args.pretitle and cfg.i18n.class.title_with_pretitle
or cfg.i18n.class.title)
:addClass(args.titleclass)
:cssText(args.titlestyle)
end
end
if args.image then
imageCell
:addClass(cfg.i18n.class.image)
:addClass(args.imageclass)
:cssText(args.imagestyle)
:wikitext(args.image)
if args.caption then
imageCell
:tag('div')
:addClass(cfg.i18n.class.caption)
:cssText(args.captionstyle)
:wikitext(args.caption)
end
end
if args.above then
root
:tag('tr')
:tag('td')
:addClass(cfg.i18n.class.above)
:addClass(args.aboveclass)
:cssText(args.abovestyle)
:newline() -- newline required for bullet-points to work
:wikitext(args.above)
end
local rowNums = {}
for k, v in pairs(args) do
k = '' .. k
local num = k:match('^heading(%d+)$') or k:match('^content(%d+)$')
if num then table.insert(rowNums, tonumber(num)) end
end
table.sort(rowNums)
-- remove duplicates from the list (e.g. 3 will be duplicated if both heading3
-- and content3 are specified)
for i = #rowNums, 1, -1 do
if rowNums[i] == rowNums[i - 1] then
table.remove(rowNums, i)
end
end
for i, num in ipairs(rowNums) do
local heading = args['heading' .. num]
if heading then
root
:tag('tr')
:tag('th')
:addClass(cfg.i18n.class.heading)
:addClass(args.headingclass)
:addClass(args['heading' .. num .. 'class'])
:cssText(args.headingstyle)
:cssText(args['heading' .. num .. 'style'])
:newline()
:wikitext(heading)
end
local content = args['content' .. num]
if content then
root
:tag('tr')
:tag('td')
:addClass(hasSubgroup(content) and cfg.i18n.class.content_with_subgroup
or cfg.i18n.class.content)
:addClass(args.contentclass)
:addClass(args['content' .. num .. 'class'])
:cssText(args.contentstyle)
:cssText(args['content' .. num .. 'style'])
:newline()
:wikitext(content)
:done()
-- Without a linebreak after the </td>, a nested list like
-- "* {{hlist| ...}}" doesn't parse correctly.
:newline()
end
end
if args.below then
root
:tag('tr')
:tag('td')
:addClass(cfg.i18n.class.below)
:addClass(args.belowclass)
:cssText(args.belowstyle)
:newline()
:wikitext(args.below)
end
if not child then
if args.navbar ~= cfg.i18n.navbar_none and args.navbar ~= cfg.i18n.navbar_off and
(args.name or frame:getParent():getTitle():gsub(cfg.i18n.pattern.sandbox, '') ~=
cfg.i18n.title_not_to_add_navbar) then
root
:tag('tr')
:tag('td')
:addClass(cfg.i18n.class.navbar)
:cssText(args.navbarstyle)
:wikitext(require('Module:Navbar')._navbar{
args.name,
mini = 1,
fontstyle = args.navbarfontstyle
end
end
local base_templatestyles = frame:extensionTag{
name = 'templatestyles', args = { src = cfg.i18n.templatestyles }
local templatestyles = ''
if args['templatestyles'] and args['templatestyles'] ~= '' then
name = 'templatestyles', args = { src = args['templatestyles'] }
end
local child_templatestyles = ''
if args['child templatestyles'] and args['child templatestyles'] ~= '' then
child_templatestyles = frame:extensionTag{
name = 'templatestyles', args = { src = args['child templatestyles'] }
end
local grandchild_templatestyles = ''
if args['grandchild templatestyles'] and args['grandchild templatestyles'] ~= '' then
grandchild_templatestyles = frame:extensionTag{
name = 'templatestyles', args = { src = args['grandchild templatestyles'] }
end
return table.concat({
base_templatestyles,
templatestyles,
child_templatestyles,
grandchild_templatestyles,
tostring(root),
(child and cfg.i18n.category.child or ''),
end
local function list_title(args, is_centered_list_titles, num)
local title_text = trimAndAddAutomaticNewline(args['list' .. num .. 'title']
or cfg.i18n.default_list_title)
local title
if is_centered_list_titles then
-- collapsible can be finicky, so provide some CSS/HTML to support
title = mw.html.create('div')
:addClass(cfg.i18n.class.list_title_centered)
:wikitext(title_text)
else
title = mw.html.create()
end
local title_container = mw.html.create('div')
:addClass(cfg.i18n.class.list_title)
-- don't /need/ a listnumtitleclass because you can do
-- .templateclass .listnumclass .sidebar-list-title
:addClass(args.listtitleclass)
:cssText(args.listtitlestyle)
:cssText(args['list' .. num .. 'titlestyle'])
:node(title)
:done()
return title_container
end
Main entry point for sidebar with collapsible lists.
Does the work of creating the collapsible lists themselves and including them
into the args.
function p.collapsible(frame)
local args = getArgs(frame)
if not args.name and
frame:getParent():getTitle():gsub(cfg.i18n.pattern.collapse_sandbox, '') ==
cfg.i18n.collapse_title_not_to_add_navbar then
args.navbar = cfg.i18n.navbar_none
end
local contentArgs = {}
local is_centered_list_titles
if args['centered list titles'] and args['centered list titles'] ~= '' then
is_centered_list_titles = true
else
is_centered_list_titles = false
end
local num = string.match(k, '^list(%d+)$')
if num then
local expand = args.expanded and
(args.expanded == 'all' or args.expanded == args['list' .. num .. 'name'])
local row = mw.html.create('div')
row
:addClass(cfg.i18n.class.list)
:addClass('mw-collapsible')
:addClass((not expand) and 'mw-collapsed' or nil)
:addClass(args['list' .. num .. 'class'])
:cssText(args.listframestyle)
:cssText(args['list' .. num .. 'framestyle'])
:node(list_title(args, is_centered_list_titles, num))
:tag('div')
:addClass(cfg.i18n.class.list_content)
:addClass('mw-collapsible-content')
-- don't /need/ a listnumstyleclass because you can do
-- .templatename .listnumclass .sidebar-list
:addClass(args.listclass)
:cssText(args.liststyle)
:cssText(args['list' .. num .. 'style'])
:wikitext(trimAndAddAutomaticNewline(args['list' .. num]))
contentArgs['content' .. num] = tostring(row)
end
end
for k, v in pairs(contentArgs) do
args[k] = v
end
return p.sidebar(frame, args, cfg.i18n.class.collapse)
end
return p
