Module:String
Documentation for this module may be created at Module:String/doc
This module is intended to provide access to basic string functions.
Most of the functions provided here can be invoked with named parameters,
unnamed parameters, or a mixture. If named parameters are used, Mediawiki will
automatically remove any leading or trailing whitespace from the parameter.
Depending on the intended use, it may be advantageous to either preserve or
remove such whitespace.
Global options
ignore_errors: If set to 'true' or 1, any error condition will result in
an empty string being returned rather than an error message.
error_category: If an error occurs, specifies the name of a category to
include with the error message. The default category is
[Category:Errors reported by Module String].
no_category: If set to 'true' or 1, no category will be added if an error
is generated.
Unit tests for this module are available at Module:String/tests.
local str = {}
len
This function returns the length of the target string.
Usage:
{{#invoke:String|len|target_string|}}
OR
{{#invoke:String|len|s=target_string}}
Parameters
s: The string whose length to report
If invoked using named parameters, Mediawiki will automatically remove any leading or
trailing whitespace from the target string.
function str.len( frame )
local new_args = str._getParameters( frame.args, {'s'} )
local s = new_args['s'] or ''
return mw.ustring.len( s )
end
sub
This function returns a substring of the target string at specified indices.
Usage:
{{#invoke:String|sub|target_string|start_index|end_index}}
OR
{{#invoke:String|sub|s=target_string|i=start_index|j=end_index}}
Parameters
s: The string to return a subset of
i: The fist index of the substring to return, defaults to 1.
j: The last index of the string to return, defaults to the last character.
The first character of the string is assigned an index of 1. If either i or j
is a negative value, it is interpreted the same as selecting a character by
counting from the end of the string. Hence, a value of -1 is the same as
selecting the last character of the string.
If the requested indices are out of range for the given string, an error is
reported.
function str.sub( frame )
local new_args = str._getParameters( frame.args, { 's', 'i', 'j' } )
local i = tonumber( new_args['i'] ) or 1
local j = tonumber( new_args['j'] ) or -1
local len = mw.ustring.len( s )
-- Convert negatives for range checking
if i < 0 then
i = len + i + 1
end
if j < 0 then
j = len + j + 1
end
if i > len or j > len or i < 1 or j < 1 then
return str._error( 'String subset index out of range' )
end
if j < i then
return str._error( 'String subset indices out of order' )
end
return mw.ustring.sub( s, i, j )
end
This function implements that features of {{str sub old}} and is kept in order
to maintain these older templates.
function str.sublength( frame )
local i = tonumber( frame.args.i ) or 0
local len = tonumber( frame.args.len )
return mw.ustring.sub( frame.args.s, i + 1, len and ( i + len ) )
end
_match
This function returns a substring from the source string that matches a
specified pattern. It is exported for use in other modules
Usage:
strmatch = require("Module:String")._match
sresult = strmatch( s, pattern, start, match, plain, nomatch )
Parameters
s: The string to search
pattern: The pattern or string to find within the string
start: The index within the source string to start the search. The first
character of the string has index 1. Defaults to 1.
match: In some cases it may be possible to make multiple matches on a single
string. This specifies which match to return, where the first match is
match= 1. If a negative number is specified then a match is returned
counting from the last match. Hence match = -1 is the same as requesting
the last match. Defaults to 1.
plain: A flag indicating that the pattern should be understood as plain
text. Defaults to false.
nomatch: If no match is found, output the "nomatch" value rather than an error.
For information on constructing Lua patterns, a form of [regular expression], see:
* http://www.lua.org/manual/5.1/manual.html#5.4.1
* http://www.mediawiki.org/wiki/Extension:Scribunto/Lua_reference_manual#Patterns
* http://www.mediawiki.org/wiki/Extension:Scribunto/Lua_reference_manual#Ustring_patterns
-- This sub-routine is exported for use in other modules
function str._match( s, pattern, start, match_index, plain_flag, nomatch )
if s == '' then
return str._error( 'Target string is empty' )
end
if pattern == '' then
return str._error( 'Pattern string is empty' )
end
start = tonumber(start) or 1
if math.abs(start) < 1 or math.abs(start) > mw.ustring.len( s ) then
return str._error( 'Requested start is out of range' )
end
if match_index == 0 then
return str._error( 'Match index is out of range' )
end
if plain_flag then
pattern = str._escapePattern( pattern )
end
local result
if match_index == 1 then
-- Find first match is simple case
result = mw.ustring.match( s, pattern, start )
else
if start > 1 then
s = mw.ustring.sub( s, start )
end
local iterator = mw.ustring.gmatch(s, pattern)
if match_index > 0 then
-- Forward search
for w in iterator do
match_index = match_index - 1
result = w
break
end
end
else
-- Reverse search
local result_table = {}
local count = 1
result_table[count] = w
count = count + 1
end
result = result_table[ count + match_index ]
end
end
if result == nil then
if nomatch == nil then
return str._error( 'Match not found' )
else
return nomatch
end
else
return result
end
end
match
specified pattern.
Usage:
{{#invoke:String|match|source_string|pattern_string|start_index|match_number|plain_flag|nomatch_output}}
OR
{{#invoke:String|match|s=source_string|pattern=pattern_string|start=start_index
|match=match_number|plain=plain_flag|nomatch=nomatch_output}}
Parameters
trailing whitespace from each string. In some circumstances this is desirable, in
other cases one may want to preserve the whitespace.
If the match_number or start_index are out of range for the string being queried, then
this function generates an error. An error is also generated if no match is found.
If one adds the parameter ignore_errors=true, then the error will be suppressed and
an empty string will be returned on any failure.
-- This is the entry point for #invoke:String|match
function str.match( frame )
local new_args = str._getParameters( frame.args, {'s', 'pattern', 'start', 'match', 'plain', 'nomatch'} )
local start = tonumber( new_args['start'] ) or 1
local plain_flag = str._getBoolean( new_args['plain'] or false )
local pattern = new_args['pattern'] or ''
local match_index = math.floor( tonumber(new_args['match']) or 1 )
local nomatch = new_args['nomatch']
return str._match( s, pattern, start, match_index, plain_flag, nomatch )
end
pos
This function returns a single character from the target string at position pos.
Usage:
{{#invoke:String|pos|target_string|index_value}}
OR
{{#invoke:String|pos|target=target_string|pos=index_value}}
Parameters
target: The string to search
pos: The index for the character to return
trailing whitespace from the target string. In some circumstances this is desirable, in
The first character has an index value of 1.
If one requests a negative value, this function will select a character by counting backwards
from the end of the string. In other words pos = -1 is the same as asking for the last character.
A requested value of zero, or a value greater than the length of the string returns an error.
function str.pos( frame )
local new_args = str._getParameters( frame.args, {'target', 'pos'} )
local target_str = new_args['target'] or ''
local pos = tonumber( new_args['pos'] ) or 0
if pos == 0 or math.abs(pos) > mw.ustring.len( target_str ) then
return str._error( 'String index out of range' )
end
return mw.ustring.sub( target_str, pos, pos )
end
str_find
This function duplicates the behavior of {{str_find}}, including all of its quirks.
This is provided in order to support existing templates, but is NOT RECOMMENDED for
new code and templates. New code is recommended to use the "find" function instead.
Returns the first index in "source" that is a match to "target". Indexing is 1-based,
and the function returns -1 if the "target" string is not present in "source".
Important Note: If the "target" string is empty / missing, this function returns a
value of "1", which is generally unexpected behavior, and must be accounted for
separatetly.
function str.str_find( frame )
local new_args = str._getParameters( frame.args, {'source', 'target'} )
local source_str = new_args['source'] or ''
if target_str == '' then
return 1
end
local start = mw.ustring.find( source_str, target_str, 1, true )
if start == nil then
start = -1
end
return start
end
find
This function allows one to search for a target string or pattern within another
string.
Usage:
{{#invoke:String|find|source_str|target_string|start_index|plain_flag}}
OR
{{#invoke:String|find|source=source_str|target=target_str|start=start_index|plain=plain_flag}}
Parameters
source: The string to search
target: The string or pattern to find within source
start: The index within the source string to start the search, defaults to 1
plain: Boolean flag indicating that target should be understood as plain
text and not as a Lua style regular expression, defaults to true
trailing whitespace from the parameter. In some circumstances this is desirable, in
This function returns the first index >= "start" where "target" can be found
within "source". Indices are 1-based. If "target" is not found, then this
function returns 0. If either "source" or "target" are missing / empty, this
function also returns 0.
This function should be safe for UTF-8 strings.
function str.find( frame )
local new_args = str._getParameters( frame.args, {'source', 'target', 'start', 'plain' } )
local pattern = new_args['target'] or ''
local start_pos = tonumber(new_args['start']) or 1
local plain = new_args['plain'] or true
if source_str == '' or pattern == '' then
return 0
end
plain = str._getBoolean( plain )
local start = mw.ustring.find( source_str, pattern, start_pos, plain )
start = 0
end
return start
end
replace
This function allows one to replace a target string or pattern within another
string.
Usage:
{{#invoke:String|replace|source_str|pattern_string|replace_string|replacement_count|plain_flag}}
OR
{{#invoke:String|replace|source=source_string|pattern=pattern_string|replace=replace_string|
count=replacement_count|plain=plain_flag}}
Parameters
pattern: The string or pattern to find within source
replace: The replacement text
count: The number of occurences to replace, defaults to all.
plain: Boolean flag indicating that pattern should be understood as plain
function str.replace( frame )
local new_args = str._getParameters( frame.args, {'source', 'pattern', 'replace', 'count', 'plain' } )
local replace = new_args['replace'] or ''
local count = tonumber( new_args['count'] )
return source_str
end
if plain then
replace = mw.ustring.gsub( replace, "%%", "%%%%" ) --Only need to escape replacement sequences.
end
local result
if count ~= nil then
result = mw.ustring.gsub( source_str, pattern, replace, count )
else
result = mw.ustring.gsub( source_str, pattern, replace )
end
return result
end
simple function to pipe string.rep to templates.
function str.rep( frame )
local repetitions = tonumber( frame.args[2] )
if not repetitions then
return str._error( 'function rep expects a number as second parameter, received "' .. ( frame.args[2] or '' ) .. '"' )
end
return string.rep( frame.args[1] or '', repetitions )
end
escapePattern
This function escapes special characters from a Lua string pattern. See [1]
for details on how patterns work.
[1] https://www.mediawiki.org/wiki/Extension:Scribunto/Lua_reference_manual#Patterns
Usage:
{{#invoke:String|escapePattern|pattern_string}}
Parameters
pattern_string: The pattern string to escape.
function str.escapePattern( frame )
local pattern_str = frame.args[1]
if not pattern_str then
return str._error( 'No pattern string specified' )
end
local result = str._escapePattern( pattern_str )
return result
end
count
This function counts the number of occurrences of one string in another.
function str.count(frame)
local args = str._getParameters(frame.args, {'source', 'pattern', 'plain'})
local source = args.source or ''
local pattern = args.pattern or ''
local plain = str._getBoolean(args.plain or true)
if plain then
pattern = str._escapePattern(pattern)
end
local _, count = mw.ustring.gsub(source, pattern, '')
return count
end
endswith
This function determines whether a string ends with another string.
function str.endswith(frame)
local args = str._getParameters(frame.args, {'source', 'pattern'})
-- All strings end with the empty string.
return "yes"
end
if mw.ustring.sub(source, -mw.ustring.len(pattern), -1) == pattern then
return "yes"
else
return ""
end
end
join
Join all non empty arguments together; the first argument is the separator.
Usage:
{{#invoke:String|join|sep|one|two|three}}
function str.join(frame)
local args = {}
local sep
for _, v in ipairs( frame.args ) do
if sep then
if v ~= '' then
table.insert(args, v)
end
else
sep = v
end
end
return table.concat( args, sep or '' )
end
Helper function that populates the argument list given that user may need to use a mix of
named and unnamed parameters. This is relevant because named parameters are not
identical to unnamed parameters due to string trimming, and when dealing with strings
we sometimes want to either preserve or remove that whitespace depending on the application.
function str._getParameters( frame_args, arg_list )
local new_args = {}
local index = 1
local value
for _, arg in ipairs( arg_list ) do
value = frame_args[arg]
if value == nil then
value = frame_args[index]
index = index + 1
end
new_args[arg] = value
end
return new_args
end
Helper function to handle error messages.
function str._error( error_str )
local frame = mw.getCurrentFrame()
local error_category = frame.args.error_category or 'Errors reported by Module String'
local ignore_errors = frame.args.ignore_errors or false
local no_category = frame.args.no_category or false
if str._getBoolean(ignore_errors) then
return ''
end
local error_str = '<strong class="error">String Module Error: ' .. error_str .. '</strong>'
if error_category ~= '' and not str._getBoolean( no_category ) then
error_str = '[[Category:' .. error_category .. ']]' .. error_str
end
return error_str
end
Helper Function to interpret boolean strings
function str._getBoolean( boolean_str )
local boolean_value
if type( boolean_str ) == 'string' then
boolean_str = boolean_str:lower()
if boolean_str == 'false' or boolean_str == 'no' or boolean_str == '0'
or boolean_str == '' then
boolean_value = false
else
boolean_value = true
end
elseif type( boolean_str ) == 'boolean' then
boolean_value = boolean_str
else
error( 'No boolean value found' )
end
return boolean_value
end
Helper function that escapes all pattern characters so that they will be treated
as plain text.
function str._escapePattern( pattern_str )
return mw.ustring.gsub( pattern_str, "([%(%)%.%%%+%-%*%?%[%^%$%]])", "%%%1" )
end
return str
