Tormach PCNC 1100
(Redirected from Tormach PCNC1100)
The Tormach PCNC 1100 is in an enclosure in the corner of the metal shop, to the right of the Rong Fu RF-45 Mill.
Tormach PCNC 1100 Series 3
  • 1.5hp R8 Spindle
  • Table Size: 34" x 9.5"
  • Table Slots: 3 Slots 5/8"
This machine rotates the spindle very rapidly. Don't wear loose clothing when operating this machine. It may be hard to see exactly where rapidly spinning tools are, particularly fly cutters.
Do not reach into the enclosure while the machine is moving. The space bar triggers FEEDHOLD, which stops feeding, but does not stop the spindle. Stop the spindle as well as stopping feeding (bed movement) by sliding the RPM slider to 0% on the console. The STOP button will reset your program to the beginning.
Keep the enclosure doors closed as much as possible. Objects may be sent flying in any direction, including detached pieces, or the entire part being machined if work holding fails.
The Tormach is used for CNC machining. It can be used to create precise parts out of a variety of metals and plastics.
With the proper tooling, many materials can be machined. Common choices include Aluminum, Steel, and Acetal plastic ("Delrin").
Maximum Sizes and Weights
  • Weight: 500 lbs
Pre-mixed cutting fluid is provided on shelves to the right of the machine, behind the computer stand. If there is no pre-mixed fluid remaining, distilled water can be used temporarily. Contact a steward or submit a problem report if there are less than 4 bottles of coolant.
Feeds and Speeds
Setup
Basic Operation
Turning on the Machine
  • Check the oiler, which is on the lower left side of the machine. Contact a steward if the oil level is low. If you turn the machine on while the oil level is low it will make a very loud alarm noise and the alarm LED will flash. The oiler wants ISO VG 68 oil, like Mobil Vectra 2 Way Oil.
  • Oil reservoir level
  • Check the coolant pressure. Open the valve fully and click the COOLANT button on the console (shortcut ALT-F). The stream should have enough pressure to remain straight over several inches. If you need to add coolant, it is kept in pre-mixed gallon bottles to the right of the machine, behind the computer stand. Give it a good shake to mix it before adding it to the reservoir. You can pour the coolant into the drain in the enclosure. Pay attention to the coolant pressure as you operate the tool. If it gets low, pause your job and add more coolant. Overfilling will cause the coolant reservoir to leak onto the floor.
Transferring Files
Preparing Tools
  • Tool holders and a limited selection of tools can be found in the black cabinet under the bench.
    • To place a tool in an ER20 collet, choose the correct size of collet and ensure it is free of chips, place into the collet nut so that the face of the collet is flush with the nut, lightly tighten the nut onto the tool holder, insert the tool, tighten the nut.
    • There is a tool tightening fixture mounted on the bench. To tighten, insert the collet in the right side of the bushing and tighten with the wrench. To loosen, insert the collet in the left side of the bushing and loosen with the wrench
  • Location of TTS tightening tools.
Inserting & Removing Tools
  • To insert:
    • Open the spindle cover door
  • To remove:
Work Holding
    • The fixture plate is 34" x 12". The Tormach travel is only 18" x 9.5". This means that much of the fixture plate can't be reached by the spindle, so before fixturing a part to the table, make sure it will be accessible.
    • The holes are spaced 1.25" on-center
    • Diagram with dimensions
Referencing
  • Click Ref X and Ref Y
Probing
  • The probe connects to the machine via a 4 pin CNLINKO LP-12 waterproof locking connector, and a USB-C cable to the probe. If the cable is not well connected to the probe or machine for any reason, please red tag the machine so we can address that issue to prevent crashing and ruining the probe.
  • To start, ALWAYS plug the cable into the 4 pin LP-12 connector first. The probe will light up green when the connection is good. DO NOT proceed if the light is not on. The machine will happily crash and ruin the probe if you run a probing routine without power to the probe.
  • Put the probe back in the tool chest when you're done, and put the rubber cover back over the machine's connector to keep coolant and chips out of it.
    • There is a squeegee and brush on the left side of the machine. Use them to remove coolant and chips from the walls of the enclosure. Squeegee the table/fixture plate as well
Software
Tooling
Machining Shop Space Team
SIG Information
Speeds and Feeds Resources
Common Projects
