Laguna iQ CNC
Revision as of 19:40, 24 February 2024 by Morrism14 (talk | contribs) (Added prohibition of cutting fluids and guidelines for cutting soft metals.)
Asmbly recently acquired a Laguna IQ Desktop CNC. It uses the same software and workflow as the Laguna Swift Vacuum CNC, but with a 24" x 36" work surface using conventional hold-downs.
ClassWarningIcon.png Members must complete the Intro to CNC Routers Class before using this tool
The Laguna IQ CNC has a 3hp continuous-duty liquid-cooled spindle. It can make any cut the big CNC can make.
