Laguna iQ CNC
Asmbly recently acquired a Laguna IQ Desktop CNC. It uses the same software and workflow as the Laguna Swift Vacuum CNC, but with a 24" x 36" work surface using conventional hold-downs.
Members must complete the Intro to CNC Routers Class before using this tool
The Laguna IQ CNC has a 3hp continuous-duty liquid-cooled spindle. It can make any cut the big CNC can make.
This should serve as a reference on how to properly finish up your CNC session. Please pay special attention to #6.
- Take out bit. Remove/return nut and collet to toolbox.
- Turn off workholding vacuum, remove hold-downs, vacuum spoilboard, use chisel to flatten bumps
- Use vacuum/broom to clean around machine. Don’t use airgun to just blow it away!
- Sign out of Vcarve and the browser. Return shared USB drive to toolkit
- Shut down machine using procedure on laminated sheet
- Empty DC - both the separator and the bag
- Take large scraps to dumpster
- Return/organize/close CNC toolboxes
- Post cool pictures of your project on Discourse to encourage other members and build community
