Grizzly G0569 Bandsaw
Revision as of 15:06, 23 October 2023 by Cfstaley (talk | contribs) (Updated brake procedure.)
Grizzly G0569 is a 7.5hp resaw monster.
Do not cut metal with this tool. This bandsaw is to be used for wood only, and only for resawing or straight cuts. No curves.
For this saw, the red button on the power panel is the off button. If you use this button, you will need to twist it to reset it.
The brake pedal is mainly for emergency use. If you do use the brake pedal, push gently. It will take a little while for the blade to stop running. The brake pedal will shut power off to the saw.
No adjustments allowed, except for Fence & Cutting height.
This saw takes a 180" blade. We typically equip it with a 1" 3tpi Timber Wolf resaw blade.
  • No blade changes - call a steward or report via red QR code.
  • Do not adjust bearings or tension. Do not release tension.
  • If you see a problem that you think needs these adjustments, report using any red QR code.
If you are cutting logs, use a fixture. You will have to build your own. It is a good idea to run a metal detector across logs.
Maximum cutting height is 16¼", maximum cutting width is 24½"
The cast-iron fence isn't super tall. We keep sacrificial MDF fences around to help with resawing taller material.
