Precision Matthews CS-350 Cold Saw
Asmbly has purchased a Precision Matthews CS-350 3hp, 14" cold saw. This saw is used to make precision, repeatable cross and miter cuts in metal bar stock.
- Variable blade speed for the best cutting speed to match the job from 24-120 RPM
- Quick Acting lever for angle changes, can be done in only a few seconds
- This saw has a 90 degree swivel head, for slotting capability
- Quick Acting vise lever, for faster operation on multiple cuts of the same size
- Miters 45 degrees, both ways (Left and Right)
- Adjustable Work Stop with Inch/MM Readings included as standard equipment, for faster repetitive cuts
- Recirculating Coolant System is standard equipment
Cutting Capacities
| Angle | Bar | Round Tube | Square Tube | Rectangular Tube |
| 0º | 3.5" | 4.7" | 4"x4" | 6.3"x3.5" |
| 45º | 3" | 4" | 4.5"x4.5" | 3.5"x2.8" |
