Precision Matthews CS-350 Cold Saw
Revision as of 16:23, 2 November 2023 by Jon (talk | contribs)
Asmbly has purchased a Precision Matthews CS-350 3hp, 14" cold saw. This saw is used to make precision, repeatable cross and miter cuts in metal bar stock.
  • Variable blade speed for the best cutting speed to match the job from 24-120 RPM
  • Quick Acting lever for angle changes, can be done in only a few seconds
  • This saw has a 90 degree swivel head, for slotting capability
  • Quick Acting vise lever, for faster operation on multiple cuts of the same size
  • Miters 45 degrees, both ways (Left and Right)
  • Adjustable Work Stop with Inch/MM Readings included as standard equipment, for faster repetitive cuts
  • Recirculating coolant system protects blade and workpiece
Cutting Capacities
Angle Bar Round Tube Square Tube Rectangular Tube
3.5" 4.7" 4"x4" 6.3"x3.5"
45º 3" 4" 4.5"x4.5" 3.5"x2.8"
