Metal Lathe Class
Revision as of 03:20, 7 January 2023 by Jon (talk | contribs) (Jon moved page Lathe Class to Metal Lathe Class without leaving a redirect)
Description
The metal lathe is one of the 2 tools you could use to rebuild the entire world. Its versatility is very understated. Prior to the invention of the metal lathe we could only get close to being round. Making spacers, turning a new handle, properly drilling a hole in round stock, and cleaning up round stock.
Update: I got some new Iscar carbide inserts that are capable cutting steel and aluminum. The main difference is the rpms for the two types of metal.
Syllabus
- Safety
- How to use the aluminum chop saw for cutting stock
- Parts of the metal lathe
- How to indicate a part
- How to face a part
- How to turn a part
- How to center drill, drill, and use a boring bar
- How to knurl
- How to part a part
- Clean up procedure
You will get a handout, a greater appreciation of the metal lathe, an Iscar carbide insert, and an aluminum keepsake.
This is an active class at Asmbly. If you can't find an upcoming session in the Class Schedule, email education@asmbly.org for more information.
