Laguna TFlux 5 Dust Collector
Revision as of 20:07, 27 March 2024 by Ewei (talk | contribs)
iVac Tool Pro/Blast Gate ID Codes
Machine ID Code Individual Power or USB Hub System Address
West Bend Edge Belt Sander 010010 B
Powermatic Combo Belt/Disc Sander 000001 A
Bosch Miter Saw 000010 A
Laguna Jointer 000011 A
Table Saws (both share gate) 000100 A
Powermatic Planer 000101 A
Router Table 000110 A
Supermax Drum Sander 000111 A
Grizzly G0569 Bandsaw 010000 B
Powermatic Large Belt Sander 010001 B
Grizzly G0817 - A01 Blast Gate D
Grizzly G0817 (1) 110010 Individual D
Grizzly G0817 (2) 110100 Individual D
