Lightburn
Revision as of 02:32, 2 June 2024 by Bwatt (talk | contribs) (Moved from Tarkin onto its own Lightburn page)
A Lightburn Material Database for Tarkin's material settings ready to install on your machine is located here [TBD: add '$wgFileExtensions = array( "clb", lbset" );' to LocalSettings.php]
