Tormach PCNC 1100 Overhaul
Specifications
- 1.5hp R8 Spindle
- Table Size: 34" x 9.5"
- Table Slots: 3 Slots 5/8"
Required Classes and PPE
You must take the Tormach Class before using this machine.
No special PPE is required for this machine, but hearing protection is advised in addition to the general shop requirements of safety glasses and closed-toed shoes. Safety glasses may be found on a shelf on the back side of the Tormach enclosure, near the horizontal bandsaw.
Feeds and Speeds
Maximum Sizes and Weights
With the proper tooling, many materials can be machined. Common choices are Aluminum, Steel, and Acetal plastic ("Delrin").
Setup
Setup guide / workflow
Turning on the Machine
- Check the oiler
WHICH IS SOMEWHERE
.CONTACT A STEWARD IF THE OIL LEVEL IS LOW?
- Check the coolant reservoir. To see the level, look
WHERE THE COOLANT LEVEL IS CHECKED
. Top up, if necessary- Coolant should be made with
X PARTS DISTILLED WATER AND Y PARTS NAME OF COOLANT MIXTURE
Preparing Tools
- For common tool sizes, 1/8", 1/4", 3/8", and 1/2" ER20 collets are available, as are two sizes of drill chuck. See Tormach Owner's Guide for details.
- There is a tool tightening fixture mounted on the cabinet top.
DESCRIPTION OF HOW TO USE
- After securing tools in the tool holder, measure their lengths using the surface plate and
MICROMETER?
Work Holding
- Treat the fixture plate as a precision instrument. It is precision ground out of 6061 Aluminum, and won't function correctly for long term use if it excessively nicked or scratched.
Probing
SIG Information
