Tormach PCNC 1100 Overhaul
Specifications
- 1.5hp R8 Spindle
- Table Size: 34" x 9.5"
- Table Slots: 3 Slots 5/8"
Required Classes and PPE
You must take the Tormach Class before using this machine.
No special PPE is required for this machine, but hearing protection is advised in addition to the general shop requirements of safety glasses and closed-toed shoes. Safety glasses may be found on a shelf on the back side of the Tormach enclosure, near the horizontal bandsaw.
Feeds and Speeds
Maximum Sizes and Weights
Setup
Turning on the Machine
- Check the oiler
WHICH IS SOMEWHERE
.CONTACT A STEWARD IF THE OIL LEVEL IS LOW?
- Check the coolant reservoir. To see the level, look
WHERE THE COOLANT LEVEL IS CHECKED
. Top up, if necessary- Coolant should be made with
X PARTS DISTILLED WATER AND Y PARTS NAME OF COOLANT MIXTURE
Preparing Tools
- For common tool sizes, 1/8", 1/4", 3/8", and 1/2" ER20 collets are available, as are two sizes of drill chuck. See Tormach Owner's Guide for details.
- There is a tool tightening fixture mounted on the cabinet top.
DESCRIPTION OF HOW TO USE
Inserting & Removing Tools
- To insert:
- Open the spindle cover door
- To remove:
Work Holding
Referencing
- Click Ref X and Ref Y
Probing
Turning off the machine
- There is a squeegee on the left side of the machine. Use it to remove coolant and chips from the walls of the enclosure. Squeegee the table as well
- Use a wet/dry vac to clean up chips
Tooling
IS IT ALLOWED/ENCOURAGED TO USE THE TOOLING FROM THE MANUAL MILL IN THE CABINET NEXT TO THE SURFACING WHEEL?
SIG Information
- Look at the tool paths on the display. Do they look correct?
