Tormach PCNC 1100 Overhaul
Revision as of 00:13, 9 July 2024 by Aneel (talk | contribs)
🛑 This page is a work in progress for the Wiki Overhaul project. Please visit Tormach PCNC 1100 for authoritative information. Any text in MONOSPACE is placeholder text.
Tormach PCNC 1100 Series 3
  • 1.5hp R8 Spindle
  • Table Size: 34" x 9.5"
  • Table Slots: 3 Slots 5/8"
Maximum Sizes and Weights
  • Weight: 500 lbs
Distilled water can be found underneath the tool. Coolant mix is in a bucket in the tool cabinet under the loft.
Feeds and Speeds
Setup
There is a rotary power switch inside the enclosure on the right side of the machine. There is a start button and an emergency stop button (E-stop) above the enclosure doors. The console is on a swinging arm on the right side of the enclosure.
Basic Operation
Turning on the Machine
  • Check the oiler WHICH IS SOMEWHERE. CONTACT A STEWARD IF THE OIL LEVEL IS LOW?
  • Check the coolant reservoir. To see the level, look WHERE THE COOLANT LEVEL IS CHECKED. Top up, if necessary
    • Coolant should be made with X PARTS DISTILLED WATER AND Y PARTS NAME OF COOLANT MIXTURE
Transferring Files
  • There is a USB Hub that can read FAT-formatted USB drives. Use the Files button in the console
  • You can transfer files over the network HOW???
Preparing Tools
    • There is a tool tightening fixture mounted on the cabinet top. DESCRIPTION OF HOW TO USE
Inserting & Removing Tools
  • To insert:
    • Open the spindle cover door
  • To remove:
Work Holding
Referencing
  • Click Ref X and Ref Y
Probing
  • Use a wet/dry vac to clean up chips
Software
Fusion is installed on the computers in the Textiles room. Autodesk offers free subscriptions for educational users. Autodesk also offers a personal subscription for non-commercial use, however **be aware that it doesn't support post processing NC paths with tool changes**. Transferring projects from a personal account to another account is surprisingly difficult.
Tooling
  • IS IT ALLOWED/ENCOURAGED TO USE THE TOOLING FROM THE MANUAL MILL IN THE CABINET NEXT TO THE SURFACING WHEEL?
Machining Shop Space Team
SIG Information
  • Look at the tool paths on the display. Do they look correct?
Common Projects
