Equipment Template
Revision as of 16:21, 12 July 2024 by Cfstaley (talk | contribs) (Title change)
<INSERT PHOTO OF EQUIPMENT>
Etiquette (if relevant)
Example:
Maximum Sizes and Weights
Where to find consumables in shop like distilled water or cleaning supplies
e.g. Brooms and dust pans are at either end of the shop, by the bandsaws, by the dust collector, and by the bathroom
Feeds and Speeds
Basic Operation
Include Skedda! e.g. Using this tool requires you to book time in Skedda under "Woodshop - User" 1 thru 6.
  • What to clean
  • How to clean
  • Where to dispose of waste
Example for Miter Saw:
  1. Brush off top surface
  2. Brush around machine
  4. Sweep floor
SIG Information (if relevant)
Common Projects
