Equipment Template
Revision as of 19:59, 12 July 2024 by Cfstaley (talk | contribs) (Wording, heading titles)
<INSERT PHOTO OF EQUIPMENT>
Etiquette (if relevant)
Example:
Tool Use
  • What to clean
  • How to clean
  • Where to dispose of waste
Example for Miter Saw:
  1. Brush off top surface
  2. Brush around machine
  4. Sweep floor
SIG Information (if relevant)
Common Projects
