Tethys
| Manufacturer | Elegoo |
| Model | Elegoo Saturn 3 Ultra |
| LCD | 10-inch 12K Mono LCD |
| System | EL3D-4.0 |
| Slicer Software | CHITUBOX & Voxeldance Tango |
| Technology | MSLA Stereolithography |
| Printing Speed | Maximum 150mm/h |
| Z Axis Accuracy | 0.01mm |
| XY Resolution | 19 x 24μm (11520 x 5120) |
| Build Volume | 218.88mm(L) * 122.88mm(W) * 260mm(H) |
| Light Source | COB + Refractive Light Source (Wavelength 405 nm) |
| Weight | 16.2kg |
| Operation | 4.0-inch Capacitive Touch Screen |
| Power Requirements | 100-240V 50/60Hz 24V 7.5A |
| Printer Dimensions | 305.9mm(L) * 273mm(W) * 562.5mm(H)
Etiquette (if relevant)
Example:
Leveling the bed
Tool Use
- The build plate does not have to be cleaned every time a print is made, as it'll waste time and resin. Only clean the plate if a print failed or if something fell into the resin.
- The resin can be left in the printer for months, so long as the resin is stirred and heated before a print is made.
- The FEP sheet can be cleaned by cutting a microfiber towel into three or four slices and wiping the FEP sheet with them.
Example for Miter Saw:
- Brush off top surface
- Brush around machine
- Sweep floor
- Wall vacuum hose works well
SIG Information (if relevant)
