Tethys
Tethys (Elegoo Saturn 3 Ultra)
Manufacturer Elegoo
Model Elegoo Saturn 3 Ultra
LCD 10-inch 12K Mono LCD
System EL3D-4.0
Layer Thickness 0.01 - 0.2mm
Z Axis Accuracy 0.01mm
Weight 16.2kg
Booking Policy
The resin printers do not have a daily limit on booking time, but the time spent with the printers should include not only the print time, but also the additional time needed for pre-print and post-print tasks. Please incorporate this extra time when booking the printers. For example, if you start a resin print, but won't be back to remove it from the build plate until the next day, book the printer until the next day.
Because 3D Prints involve a lot of time when you don't need to be present, the policies are slightly different from the general booking policies.
  1. Time booked for 3D printing in Skedda does not count against your weekly usage hours, but time on the XL is limited to 48 hours per week. If you want to print a large object that will take longer, book the first 48 hours and email 3dprinters@asmbly.org to request more time. If it's available, we'll try to book it for you.
  2. It is fine for a print to continue while Asmbly is closed.
  3. You may book up to two 3D printers at a time.
  4. Book all of the time you need. Only print during time that you have booked. Don’t start prints that will go beyond your booked time. If your print has been paused or stopped because of a problem, don’t resume or restart it if it will go beyond your booked time. If time is available after your booked time, feel free to book more time to finish your print. If another member has already booked time that your print would need to use, and you contact them and get their approval, you may finish your print. However, if you do not manage to contact them, or if they do not agree to let you continue, then do not start, resume, or restart prints that would go into their time.
  5. Time you book is yours. If you arrive for your booked time and a print is ongoing, you may stop that print. If a print only has a few minutes remaining, it would be nice if you let it finish, but you are not under an obligation to do so.
  6. Give back time that you don’t need. If you realize you’ll be late, change your booking to start when you’ll actually be ready to start. If your print ends early, end your booking early in Skedda.
  7. Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened.
Resin Safety
  • Avoid breathing vapors.
Available Resin Materials
You may purchase resin here.
Chitu Box Slicer Setup
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
  8. Note from a Steward: Please be aware that at least some versions of CHITUBOX will attempt to auto correct an infrequent issue on build plate leveling by including in the slicing data a command to over shoot the the set zero that can lead to print fails by print over compression. After leveling, run a test print and then manually adjust the z height by the .1mm it is off by the calipers. As of 4/11/2025 the proper z hieght post leveling needs to be set at .9 mm above level sheet.
Post-Processing
If your print fails, particularly if some parts of the print don't adhere to the bed, it's likely you'll need to do a Resin Tank Cleanup. Please try to leave the tank debris-free for the next user.
3D Printers Space Team
Common Projects
