Tethys
Revision as of 21:19, 4 September 2024 by YellowEng (talk | contribs) (Add safety, materials, cleaning, and operations in the Saturn 3 Ultra wiki page)
Unnamed SLA Printer
Manufacturer Elegoo
Model Elegoo Saturn 3 Ultra
LCD 10-inch 12K Mono LCD
System EL3D-4.0
Layer Thickness 0.01 - 0.2mm
Z Axis Accuracy 0.01mm
Weight 16.2kg
Keep the 3D printer and its accessories out of reach of children.
Fill the resin tank no less than 1/3 of its volume, but do not exceed the MAX line position.
Place the printer in a dry environment and protect it from rain and moisture.
If you run into an emergency during use, please turn off the power supply of the 3D printer first.
Use the printer indoors and avoid direct sunlight and a dusty environment.
Use 95% ethyl alcohol or isopropyl alcohol to wash your model unless you are using water washable resin.
If the printing fails, you need to clean the excess cured resin in the resin tank and change the resin, otherwise, it may cause damage to your printer.
When operating the 3D printer, please wear a mask and gloves to avoid direct skin contact with the photopolymer resin.
If the release film in the resin tank is whitened, scratched, or has no elasticity, the printing failure rate is high, please replace the release film in time.
If you have any problems with the printer, please report them to Asmbly via QR code.
The pricing of ABS like resin and Standar resin is $0.10 per gram.
You may purchase resin here.
Chitu Box Slicer Setup
  2. Select ELEGOO Saturn 3 Ultra as the default printer.
Default Parameters in Chitu Box
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
Leveling the bed
Tool Use
SIG Information (if relevant)
Common Projects
