Tethys
| Manufacturer | Elegoo |
| Model | Elegoo Saturn 3 Ultra |
| LCD | 10-inch 12K Mono LCD |
| System | EL3D-4.0 |
| Slicer Software | CHITUBOX & Voxeldance Tango |
| Technology | MSLA Stereolithography |
| Printing Speed | Maximum 150mm/h |
| Z Axis Accuracy | 0.01mm |
| XY Resolution | 19 x 24μm (11520 x 5120) |
| Build Volume | 218.88mm(L) * 122.88mm(W) * 260mm(H) |
| Light Source | COB + Refractive Light Source (Wavelength 405 nm) |
| Weight | 16.2kg |
| Operation | 4.0-inch Capacitive Touch Screen |
| Power Requirements | 100-240V 50/60Hz 24V 7.5A |
| Printer Dimensions | 305.9mm(L) * 273mm(W) * 562.5mm(H)
- Keep the 3D printer and its accessories out of reach of children.
- If the printing fails, you need to clean the excess cured resin in the resin tank and change the resin, otherwise, it may cause damage to your printer.
The pricing of ABS like resin and Standar resin is $0.10 per gram.
You may purchase resin here.
Chitu Box Slicer Setup
- Select ELEGOO Saturn 3 Ultra as the default printer.
Default Parameters in Chitu Box
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
Leveling the bed
Tool Use
SIG Information (if relevant)
