Laguna TFlux 5 Dust Collector
- Users Manual
- iVac Pro System Guide
- iVac Blast Gate User Manual
iVac System Addresses
Usage Notes
- If desired, you can turn on the dust collector before you start using any tools.
- If you do rely on the automatic control to turn on the dust collector, please give it a 10 seconds or so to turn on and spin up.
- When changing the dust bin, please make sure other users are aware and do not use any tools, so the dust collector is not turned on without the bin.
Implementation
Since ASMBLY has two different iVac System Addresses, an iVac Pro Control is used to monitor system address C, and trigger a tool sensor on system address A. The iVac Tool Advantage Sensor has a trigger input which allows this.
