Laguna TFlux 5 Dust Collector
- Users Manual
- iVac Pro System Guide
- iVac Blast Gate User Manual
iVac System Addresses
Usage Notes
- The dust collector will automatically turn on and off. It is still the users responsibility to make sure the dust collector is on before using a woodshop tool.
- When turning on a toll when the dust collector is off, please give it a 10 seconds or so for the dust collector to spin up before using the tool.
- When changing the dust bin, please make sure other users are aware and do not use any tools, so the dust collector is not turned on without the bin in place.
- If any issues are encountered, please send a problem report.
- To disable the automatic functionality, turn the switch on the yellow box on the dust collector to "off" instead of "auto". If you do this, please submit a problem report.
| Mode | LED |
| Standby | LED flases every 4 seconds |
| On | LED on |
| 8 minute off timer | LED flashes 2x or 5x per second |
Implementation
The daisy chain setup is plugged in high above the router table.
Troubleshooting Automatic Control
- If a tool is not triggering the dust collector, verify the tool sensor is working correctly.
- verify iVac MSC is set to "auto"
- verify tool sensor is set to "auto"
- verify tool sensor LED is lit when the tool is turned on
- If the tool is on system address C, verify it is activated when the tool is turned on
- There should be a blue led you can see when it is activated
- If the dust collector is not turning off
- Check iVac MSC LED, if light steadily, it thinks a tool is on
- Verify nothing sneaky a turned on, examples:
- South Bend sander master power enabled, but belt not running
- Drum Sander belt running
- A tool sensor set to "on" instead of "auto"
- Check iVac MSC LED, if blinking at 4x per second, DC should shut off within 8 minutes
