Laguna TFlux 5 Dust Collector
- Users Manual
- iVac Pro System Guide
- iVac Blast Gate User Manual
iVac System Addresses
| Table Saw ICS51230 (Secondary Sensor) | 010111 | C | |
Usage Notes
- The dust collector will automatically turn on and off. It is still the users responsibility to make sure the dust collector is on before using a woodshop tool.
- When turning on a tool when the dust collector is off, please give it a 10 seconds or so for the dust collector to spin up before using the tool.
- When changing the dust bin:
- Please make sure other users are aware and do not use any tools
- Turn the switch on the yellow box on the dust collector to "off" instead of "auto".
- Return the mode to "auto" after the bin has been emptied.
| Mode | LED |
| Standby | LED flases every 4 seconds |
| On | LED on |
| 8 minute off timer | LED flashes 2x or 5x per second |
Implementation
The daisy chain setup is plugged in high above the router table.
Troubleshooting Automatic Control
- If a tool is not triggering the dust collector, verify the tool sensor is working correctly.
- verify iVac MSC is set to "auto"
- verify tool sensor is set to "auto"
- verify tool sensor LED is lit when the tool is turned on
- If the tool is on system address C, verify it is activated when the tool is turned on
- There should be a blue led you can see when it is activated
- Try turning all tools off, turn automatic control to off, then back to auto.
- If the dust collector is not turning off
- Check iVac MSC LED, if light steadily, it thinks a tool is on
- Verify nothing sneaky a turned on, examples:
- South Bend sander master power enabled, but belt not running
- Drum Sander belt running
- A tool sensor set to "on" instead of "auto"
- Check iVac MSC LED, if blinking at 4x per second, DC should shut off within 8 minutes
